1 - 11 of 11 Posts
just wondering if any1 has pictures of what they did to hang dual exhaust (well dual tip) to a 01-02 cougar ???
im should be getting my cat-back soon and wanted to see what people are doing
So its begun.....
I belive you need another hanger welded on. Then its pretty straight forward from there.
Theres actually a hanger location on both sides and most dual exhaust kits come with the required hangars. My trubendz kit didnt require any modification to install the exhaust and as far as i know, no one has had to make mods to any trubendz kit.
I don't think the 01-02 ones had that extra exhaust hanger there. You may need to have one welded on.
Bingo. The second (passenger side) hanger was removed on the 01-02 models, you just need to have the shop weld one in that spot. Should be easy for them.
So its begun.....
would welding stuff onto the car void my warranty ???
also doesnt your exhaust need to flex ???
NOt sure on the warranty. But I beleive the flexpipe is what handles the flexing portion. Plus your pipes will hang from rubber hangers.
Yeah, that's why the exhaust is attached to the hanger with a flexible rubber connector.
Maybe try searching on cougardb.com for installed pics.
I didn't have to modify anything on my Borla. I'm not sure how the Trubendz mounts though. I'll have to take a picture when I get home in a couple days if I remember. There were just two holes on each side of the car spaced perfect. Stuck each resonator mount in the hole, and bolted them down.
1 - 11 of 11 Posts
