What will fit?
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 22
Like Tree3Likes
Thread: What will fit?
  1. #11
    NECO Member Joeyisamadman's Avatar
    2015 Oct
    Sherbrooke, Québec
    265
    Re: What will fit?
    years of confusion have come to an end. I love you guys.
    NECO's only French Canadian!
    '00 2.5 ATX, Laser Red: ''Ella'' AKA that Rusty old thing : http://bit.ly/1VfpWlX
    '08 Smart Fortwo: ''Yeah? well My other ride's a Rear wheel drive, rear engined MERCEDES!!!''
  3. #12
    2009 Jun
    166
    Re: What will fit?
    I saw 215/55/16s on a Cougar a couple of days ago.
  4. #13
    2009 Jun
    166
    Re: What will fit?
    Anyone running 205/55/16s?
  5. Remove Advertisements
  6. #14
    NECO Member 00YellowCougarSE's Avatar
    2009 Mar
    McKees Rocks, PA
    608
    Re: What will fit?
    Quote Originally Posted by mdmerc View Post
    I was rung 205/55R16s when I used my Cougar in the winter. In the summer I run 225/50R16s
    Frank K. from Coraopolis, PA / 2000 Mercury Cougar Special Edition - Zinc Yellow
    2nd Place Stock Cougarfest 2010
    1st Place Stock Cougarfest 2011
    2nd Place Mild Cougarfest 2014
  7. #15
    2009 Jun
    166
    Re: What will fit?
    Quote Originally Posted by 00YellowCougarSE View Post
    How would you describe the difference in the ride?
  8. #16
    2009 Mar
    McKees Rocks, PA
    608
    Re: What will fit?
    Hard to say, since the winter tires are a different compound than the summer tires. Let's just say, that if I was choosing a size for every day use, I'd never go smaller, I'd go with the 225/50R16. I only went smaller in the winter for traction purposes in snow and ice.
  9. #17
    NECO Member Gold Member StuartGrant's Avatar
    2009 Jul
    Mt. Clemens, Mi
    1,955
    Re: What will fit?
    I run 195/60/R16's on my winter rims, and 225/45/R17's on my summer rims, and I've never looked at what was on the 01 since I've driven it so little.
    Ride is a combination of tire compound, size, and pressure. My winter tires (Blizzack WS80's) are kept at 36 PSI, road noise is minimal, and grips very well on snow and slush, better than my old WS60's which were 205/55R16, and are still fun to throw around in a corner. My summer tires (Bridgestone Potenza RE71R's) are kept at 38 PSI, make quite a bit of road noise, though a bit less than my old KDW2's, throw rocks at me if I stick my hand out the window, and grip the ground like nobody's business dry or wet. I benchmark my tires on a roundabout near my house, the WS60's could take it at around 35, the WS80's at around 40, the KDW2's around 45, and the RE71R's at around 48-50 without understeer.
    EPA Clean Air Act Section 609 Certified
    00' MTX 2.5L, spruce green: Died 9/13/11 - Revived 6/1/12
    '06 VW Jetta TDI, that fuel economy yo!
    '01 MTX C2, black, Murdocks old car, needs an engine or something.
  10. #18
    2015 Oct
    Sherbrooke, Québec
    265
    Re: What will fit?
    Stuart, did you have issues with clearance on the 17s, offset wise? what wheels are on the car? I'd like to up to 17s for brake / caliper clearance down the line, but between by budget and offset concerns, I'm not sure what to grab.
  11. #19
    NECO Member rooster210's Avatar
    2008 Sep
    Raeford N.C.
    1,839
    Re: What will fit?
    Not sure itll help but my 17 konig unknowns fit perfect with 225/45s. not totally sure the backspace but I bought them off ebay so you should be able to find some with the backspace listed.
    Straight lines make me giggle.
    99 frosty, Lots of mods done to it.
    black 99, upcoming tinker toy
    99 E150 Econoline coachmen conversion
    2016 Honda Civic EX Turbo
  12. #20
    NECO Member LostOffspring99's Avatar
    2014 Jul
    East Palo Alto, CA
    827
    Re: What will fit?
    I have 17x7.5 +42 Offset that fit over Baer's braking system.
    /oO___--___Oo\
    |=_/o____o\_=|
