This brake pad looks good, right? (pic)
Results 1 to 6 of 6
Thread: This brake pad looks good, right? (pic)
    THE NECO Newfie Moderator atlas's Avatar
    2001 Nov
    Newfoundland
    1,762
    Thought for sure my brake pads (fronts at least) needed to be changed, but I just removed the front passenger side pad (and this is the first time I ever done this before to any car) and thought... "this doesn't look too bad". I measured the complete thickness (pad + the metal slab the pad is connected to) and it's 0.555". Hard to measure exactly the thickness of just the pad using a caliper, but it looks about 0.33". These are the original pads on my 2001 and she's got about 48000kms (29000miles). Here's a pic:
    If this pad is okay, I just reassemble everything? No need to compress the piston using the c-clamp?
    Thanks!
    2001 V6 2.5L MTX Cougar
    Injen/GMK/Borla/Koni/GroundControl/ST200/OMP/BAT/Aerogear/Velox/NicheAudio
    Craig Lieberman from 'The Fast and the Furious': "F&%k that's loud!"
    Yamaha RX-V1700/Sony KF-E42A10/Monitor Audio BR5-BRLCR-BRFX-BRW10/PS3 80G
    NECO Member aboythatskates's Avatar
    2010 Mar
    spokane washington
    2,982
    Re: This brake pad looks good, right? (pic)
    that looks good. all it uses when u brake is that stuff on the metal. u can drive til its gone but not really advised. pretty much change brakes when there are problems with them or when that "brake" material is almost gone
    Full 3L '99 Mercury Cougar MTX.
    195 ft/lbs TQ, 199 HP.
    Quote Originally Posted by nadthomas View Post
    Man, I'm glad you figured that one out for us, that has been such a road block.
    2010 Mar
    spokane washington
    2,982
    and about the piston. u might not need to if the pads will fit over the rotor. if u cant fit them on then ul need to compress it
    is a pop sensation Lifetime Platinum MemberModerator sonza68's Avatar
    2001 Jan
    Right behind you
    13,615
    There is plenty of life left in the pad. As for compressing the piston, I would compress it a little just to make it easier to get the caliper back on. You could probably do it without compressing the piston, but you may end up fighting to get everything aligned just right for the caliper to fit back on.
    Just because I don't care doesn't mean I don't understand.
    2001 Nov
    Newfoundland
    1,762
    Thanks everyone! I reinstalled the pads and tried without compressing the piston and they went back on with ease. I checked the other side and it was exactly the same diameter 0.555". You guys are awesome!
    2010 Mar
    spokane washington
    2,982
    yep. those pads have a ton of life still left
