Help Please! Cougar AWOL
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 19
Thread: Help Please! Cougar AWOL
    NECO Member work_in_progress's Avatar
    2006 Dec
    Metairie, LA
    385
    Exclamation Help Please! Cougar AWOL
    Long story short, I decided to do my brakes and rotors myself because they were due. I've never done them before so I educated myself and bought parts and went at it. In my eagerness I mixed up the rear and front rotors, so I went to swap them out. Everything good for the most part so far, EXCEPT... well A) One of the rotors has a nice big pit in it -_- and B) My calipers won't fit over my rotors anymore, even my stock ones that were just below accepted tolerance.
    What gives? I drove for 30 min with just my front drivers rotor and pads switched out, got home switched out front pass. Next day, swapped out both rears, noticed my problem, went to fix it and now it's a no go. Car is in first, no parking brake on.
    Caliper all the way back, check.I played with it for ten min... Inside pad clipped in all the way, check. Opened up the bleeder to relieve some pressure, check. Still won't fit over the rotor...
    Break time, sorry for the HUGE post, I'm really tired, worn out and have to wake up early tomorrow.
    while I'm in this section, I was curious to know what my stock size rims were. I started a thread earlier but I forgot to post my born on date, which is 06/24/99. I've heard that there are some many variables when it comes to knowing what size you had. And I don't know if this is just happening now, but my speed seems to be off (from the speedo and digital readout) about 3-5mph around the 70mph mark. So maybe I'm thinking I had stock 15's? Currently running 16.
    Took my first Gojo shower tonight, I smell like an orange.
    ~Josh~
    '99 Vibrant White MTX
    Steeda short throw, front strutbar, Weapon-R Intake, Dual Trubendz w/ Borla.
    You never fully understand "Love/Hate relationship" until you own a Cougar.
    NECO Member BlackBetty's Avatar
    2006 Feb
    Lethbridge, Alberta
    7,247
    Re: Help Please! Cougar AWOL
    You have the sport package since you had rear discs so your rims are stock 16's.
    You can verify your speed with gps and as far as your brakes I have no clue, I'm sure someone with a little more know age will chime in.
    Sold-1999 3.0L Mercury Cougar- Cougardb // Cardomain // Fuelly
    New- 2011 Ford Fusion Sport AWD- CAI&tune. Fuelly//Cardomain
    2006 Dec
    Metairie, LA
    385
    My GPS was the thing that tipped me off to a problem. 3 different units all read about 78 when the speedo and digital readout only read just under 75. It's off from about 55MPH+
    ~Josh~
    Got 1/2 a Vanquish engine Lifetime Platinum MemberAdministrator JScullin's Avatar
    2000 Feb
    Badassachusetts
    11,330
    I've read that, like, 5 times and still can't picture what you're saying.
    First, AWOL = absent w/out leave. You're Cougar took unscheduled time off-base? It sounds like you're saying the rotors in the back are too thick? Or are the calipers fitting over it but now they won't line up w/the bracket because the rotors are too big?
    Skolenimation: Graphic Design | Modifications @ CougarDB.com
    Quote Originally Posted by BigBalledOX View Post
    This should be the thread that closes this forum permanently.
    NECO Member Terse's Avatar
    2008 Mar
    537
    You could have the dealership look up your VIN and they could tell you the original wheel size.
    2006 Dec
    Metairie, LA
    385
    Yes I know what AWOL means. Where I'm from it's used as a slang term meaning someone going crazy and checking out. Again, checking out is also used slang. And if we're getting technical, I believe AWOL could also refer to any time not reporting for duty not exclusively on-base.
    I'm sorry if the OP was garbled, I mentioned I was extremely exhausted, frusrated, and had to be up in 5 hours for work. What the problem boils down to is, I removed my caliper -with new brakes already loaded- in order to replace and incorrectly sized rotor with the correct one. When I tried to put the caliper back on it would not fit over the rotor. And I'm at a loss what I did wrong.
    Maybe it will come clear to me as I start working on it fresh tonight.
    ~Josh~
    2006 Dec
    Metairie, LA
    385
    Nevermind, figured it out.
    ~Josh~
  9. #8
    2006 Feb
    Lethbridge, Alberta
    7,247
    What was it?
  10. #9
    1% Moderator iceberg65's Avatar
    2007 Apr
    Medicine Hat, AB
    2,894
    had to compress the piston?
    The ONLY Supercharged Zetec Cougar!
  11. #10
    2006 Dec
    Metairie, LA
    385
    Quote Originally Posted by iceberg65 View Post
    Yupp. /sheepish
    ~Josh~
