| Wheels,Tires & Brakes Wheels, tires and brakes questions and information. |
Rotor Questions
Ok, I need a little bit of rotor help. My Cougar's brakes are squeaking and it's really friggin' annoying...I need new rotors, the ones on the car are shot. I've had hella trouble finding a rotor that I want. PREFERABLY I just want a quality cross-drilled rotor...I've heard that slotted and cross-drilled rotors murders your brake pads and dimpled rotors are out of the question. So could one of you guys point me in the right direction?
OH, don't you make me downshift.......*VROOOOM*
Re: Rotor Questions
normally brake squeal is caused by the pad vibrating. This can be stopped by putting a thin shim with copaslip on it behind the pad. You are right, slotted discs eat pads more quickly. I have just finished my brakes...i have 300mm up front and my old 276mm on the rear. Trust me...unless you're gonna break the land speed record, this setup is fine. I think all the parts are listed on the site. If you use stock parts, you can have very good brakes at reasonable prices...and spares are cheap and easy to find....G.
2.5L MTX. SVT ECU. 2 Cold air feeds. Hogged out MAF. 65mm P+P TB. Port matched SVT upper to SVT LIM. MSDS Headers. Optimized Y pipe. Test pipe. Wish list. 4X4 wtb aussie endlinks with poly bushes |
