Old 06-24-2008, 03:01 AM   #1 (permalink)
99 cougar v6 front rotars
i was at part source.. and they tell me there are 2 different diameter rotars...
which is the diameter for the rotars on the 99 cougar?
what would happen if i got the bigger ones?
mohamed_mourad is offline
Old 06-24-2008, 08:08 AM   #2 (permalink)
Secretary of the Inferior
B3NN3TT's Avatar
Images: 52
Re: 99 cougar v6 front rotars
The 99's were ... all over the map.
Usually, the sport package cars had larger rotors. So if you have rear disc brakes, you have larger front rotors. But early 99's sometimes didn't follow that rule, and many drum-equipped cars had larger front rotors too.
But it's a safe bet that if you have 4-wheel discs, your fronts are the larger versions.
Measure them, man.
Andy- Ohio NECO's "Green Guy"
you make my head hurt.
B3NN3TT is offline
Old 06-24-2008, 08:38 AM   #3 (permalink)
Newcat016's Avatar
Yeah, i have a 99 cougar aka build date 7/98 and it was a convenience model with the 4 wheel disc brakes,atx,etc. The fronts were 278mm(the larger ones) but a friend of mine with a 99 aka build date 5/99 and she has 260mm front's but 4 wheel disc. Take the wheel off and measure or make sure you can return them if they are the wrong size...Its screwy
Newcat016 is offline
