| Wheels,Tires & Brakes Wheels, tires and brakes questions and information. |
#11 (permalink) | ||
Go Frosty!!
Re: best tire pressure?
#13 (permalink) |
w00t!
you know what actually... I have one of those digital tire gauges, and I also have one with a actual gauge / needle, and the digital one is not very accurate. Maybe I just have a cheap one, but I would trust the pressure gauge over a digital one based on my experience.
#14 (permalink) | |
See you @ CougarFest 2008
I keep my front tires a bit higher pressure than the rear tires (34 front, 32 rear) to make up for my tendency to corner hard. One other note - measure tire pressure when the tires are "cold" - you haven't driven anywhere & the sun's not on one side/end of the car more than the other. |
#15 (permalink) | |
device has been modified
#16 (permalink) | |
I hear voices...
The slide ones are pretty inaccurate so I wouldn't use them to calibrate your digital gauge. Personally, I went with the standard version of this one: QuickCar Tire Gauge (standard, glow face or liquid filled)
#17 (permalink) | |
Won't settle 4 quick fix
If you get a good digital, those are more precise because of fewer moving parts, but cheap digitals are really no more accurate than cheap mechanicals. I prefer my mechanical dial gauge which holds the needle on the reading till you release the pressure. A lot easier to read.
#18 (permalink) |
lol he's one of those guys
![]() desolator if you live where it gets really hot during the day and cools off a lot at night the tire pressure will flucuate a lot. I have to chek my tires once a week cause az is ridiculous hot then cools way off at night. i have 225/40/r18 and i run 40 psi. You should run 32-34.
00 2.5L MTX SVT GMK <-----185 inches of sexy...
#20 (permalink) | |
The reason for the Max Tire Pressure on the tire is to match the tire with the vehicle. Say you have a F350 which is 60psi front and 80psi rear you need tires that can hold 80psi or more. As for our cars the lowest you usualy see a max tire pressure is 40psi. Therefore you have a tire that can hold what our cars need. With stock tires I wouldn't go no more than 35psi with the 215's and 33psi with the 205's. And wouldn't go no lower than 29psi with the 215's and 27psi with the 205's.
2001 2.0 I4 VCT MTX LSD, SRAI, Megans Racing Exhaust, ECU Tuned, Pioneer Head Unit, Kicker Components and Tweaters, Kicker Coaxials, Kicker 700.5 5 channel Class D Mono Amp, x2 12" Alpine Type R Subs |
