Go Back   NECO Forums > General > Videos & Pictures
Videos & Pictures Cougar-related pictures and videos.
Old 02-24-2008, 10:47 PM   #1 (permalink)
arskiracer's Avatar
Images: 2
Glovebox Thermostat & Temp Panel
Well, I finally decided to get a new digital thermostat for my car since the one I currently have is crap. When my current thermostat reaches the "on" threshold temperature, you can hear the relay buzz like crazy until it gets a few degrees above the threshold temp. I don't like that at all, so I'm going to throw that thing away.
Sorry, this picture is pretty bad, I really should buy a digital camera soon
Since my glove box used to be a fridge, the plastic has all this left over silicon and caulk all over it so I decided to cover everything with some outdoor carpet I have left over from a ramp I built for my dogs. There is a huge hole in the back of the glove box where the thermoelectric cooling module and heat sinks used to be.
Here is a good picture of the panel insert
Panel insert inside the glove box:
In this last picture you can see my little kit sled.. I didn't want to scratch my glove box all over the cement.
I used the dakota digital PAC-2000 thermostats. Each thermostat can control two devices. I'm going to use one thermostat module for the two cooling fans. The other module will control the water pump and a buzzer (buzzes when temp goes above 220F). The gauge in the center is a digital coolant temp gauge.
Adrian
2000 MTX Cougar: Mandrel 3 inch dual SS exhaust, C-SVT Engine with Vortech, Clutch Masters {stage 3 IIRC}, MSDS, B&M Shifter, Some kind of performance radiator, 55 gpm Stewart electric water pump with Dakota Digital PAC-2000 elec. prog. thermostat, Air/water intercooler from Buckshot, custom CAI, SCT Pro Racer Package(chip version)
Dyno'd 259.33 FWHP (without intercooler or CAI)
AVIC-Z1 monitor/gps, 3000 watt Xantrex Prosine 3.0 inverter
arskiracer is offline
Old 02-25-2008, 07:49 PM   #2 (permalink)
Cougar Lover, Goat Raper!
nadthomas's Avatar
Re: Glovebox Thermostat & Temp Panel
As always, its interesting.
2004 5.7L M6 Black GTO
nadthomas is offline
Old 02-26-2008, 03:04 AM   #3 (permalink)
VADriven Member
agreed
Topik is offline
Old 02-26-2008, 11:40 AM   #4 (permalink)
Need Storage Damnit
Monkeygrits's Avatar
Looks nice but are you gonna drive around with your glove box open?
Monkeygrits is offline
Old 02-26-2008, 10:25 PM   #5 (permalink)
arskiracer's Avatar
Images: 2
nope
Adrian
Old 04-05-2008, 07:41 PM   #6 (permalink)
arskiracer's Avatar
Images: 2
Well, I had to change a few things around. I forgot that I wanted to install my inverter control panel and a receptacle in there also. I ran out of room for the second thermostat module, but I'll probably just mash it behind the glovebox somewhere if I end up needing it.
Since I had to move the circular coolant gauge to the left, there was a visible hole between the gauge and the inverter panel, so I put that rubber stuff around the inverter panel to hide the hole.
Adrian
Old 04-07-2008, 08:08 PM   #7 (permalink)
arskiracer's Avatar
Images: 2
Here is the glovebox finally installed in the car
Adrian
Old 04-08-2008, 03:30 PM   #8 (permalink)
RiverRojo's Avatar
That is completely unnecessary.
75 shot ZEX, SVT swap, NGK, ADC, BAT Y-Pipe, Trubendz, Eibach, Sachs, Injen. One of the fastest ATX's but you've never heard about it.
My Cougar
Remember...watch your back and keep your noses clean.
RiverRojo is offline
Old 04-09-2008, 03:39 PM   #9 (permalink)
arskiracer's Avatar
Images: 2
I disagree
Adrian
Old 04-09-2008, 03:46 PM   #10 (permalink)
Teh box is vegas!
branchedout's Avatar
whatever happened with the massive alternator project? i know you posted that you might abandon it, but is it official?
Lost Racer : I don't do siblings...unless they're both female
Bdiddy : i love freshman. i get older, and they stay the same age. haha!
CougarGrrl99 : my sauce is yummy
308.50/219.4/199
branchedout is offline
