| Videos & Pictures Cougar-related pictures and videos. |
#31 (permalink) |
Re: Final revision done NPG Cold-Air
burrita, suprised this hasnt been asked but what happens to the intake temp sensor?. Also have you tried fitting your kit with the BAT intake tube with your intake
[I ask this because pudmonkey's heatsheild will not fit with the bat intake tube and a non-svt tb... because the adaptor adds a bit of length]
#32 (permalink) | |
#33 (permalink) | |
Driving again!! w00t!
#34 (permalink) |
Do you have the pic of it I can show you what I do with the Turbo kits. You take a 7/16-14 tap thread the pipe then take the sensor and snip the plastic bridge over the sensor tip and then use a 7/16-14 die and make threads on the IAT and screw it in the Die acts like a NPT since it is tapered. Therefore the Sensor seals as it tightens. It hold up to 16 psi on my turbo kits if you need pics let me know. Joey
PS I will tap the CAI pipes before I paint them if so and revise the description options on the site. Thanks for the heads up joey |
#35 (permalink) |
Some of the kits out there have installed the IAT into a coupler. A small hole in the rubber seems to hold the IAT in very well and it doesn't require pipe modification.
#36 (permalink) |
BTW here is a picture of the fender area that piping would have to go through. Is the Contour fender area different?
#39 (permalink) |
Hmm I was under the impression no cutting was needed. It will fit if you cut an opening for it.
#40 (permalink) |
someone call a medvac
wouldn't it be easier to just use the 3in whole saw like the old one
