Go Back   NECO Forums > General > Videos & Pictures
Videos & Pictures Cougar-related pictures and videos.
Old 08-02-2007, 06:12 AM   #1 (permalink)
arskiracer's Avatar
Images: 2
Massive Zena Alternator Custom Install
If you thought I was crazy after reading about my inverter, you're going to think I'm psychotic after seeing this.
So I have been fed up with my alternator problems. The worst part wasn't that it didn't put out enough power, it was trying to get to the stupid thing to replace or modify it. Other than that, I also didn't like the fact that every time it floods (which BION is quite often in Kingsville, TX), my alternator cuts out and then my windshield wipers might as well not even be on for how slow they run on battery. I tried two different 200A rewound "high performance" alternators and those couldn't put out even 150A at 3,000 RPM and they apparently ran way too hot and failed earlier than the stock ones I've been using. Anyway, I decided to fix all my problems by installing a true high performance Zena alternator on top of the engine where alternators are supposed to be. I'm a little more than half way done with the install and things are coming along better than I expected. I am going to have a body shop cut a giant hole in my hood and make a very large bump similar to the small one in the eclipses. I'm not really sure how that's going to look, but I'll take the functionality over the looks any day. I think the charging system is the last weak system left in my car. After this I might be finished modifying... although I'm always thinking of new things to put in my car that others wouldn't even consider.
Just like a massive erector set:
Adrian
2000 MTX Cougar: Mandrel 3 inch dual SS exhaust, C-SVT Engine with Vortech, Clutch Masters {stage 3 IIRC}, MSDS, B&M Shifter, Some kind of performance radiator, 55 gpm Stewart electric water pump with Dakota Digital PAC-2000 elec. prog. thermostat, Air/water intercooler from Buckshot, custom CAI, SCT Pro Racer Package(chip version)
Dyno'd 259.33 FWHP (without intercooler or CAI)
AVIC-Z1 monitor/gps, 3000 watt Xantrex Prosine 3.0 inverter
arskiracer is offline
Old 08-02-2007, 06:55 AM   #2 (permalink)
michcougar's Avatar
Re: Massive Zena Alternator Custom Install
Thats crazy!
Ill be keeping tabs on this to see how it turns out!
Best of luck.
Msds-Injen/GMK-magnaflow-svt-Xcal2-b&g-kyb-tezzen-clarion-earthquake
michcougar is offline
Old 08-02-2007, 08:17 AM   #3 (permalink)
brapple's Avatar
I second "thats crazy"
ever thought about relocating the coolant tank and putting it in that openning facing the other way, then you don't have to cut the hood or anything?
- 95 Mystique LS Zetec 5-spd
- 2k Contour SVT - #2137
brapple is offline
Old 08-02-2007, 10:19 AM   #4 (permalink)
Jorgen's Avatar
**** if you want a massive alternator you could have just bought on of the Heavy duty ones we sell for the big ass diesel trucks. If you really are doign this I may have to think you are crazy.
1969 Triumph Spitfire MK3
1996 Audi A4 V6 5-Speed
1999 DT Green V6 MTX Built 8/7/98. She's got a few mods.
2004 Explorer XLT, V6, Auto, 4x4
Jorgen is offline
Old 08-02-2007, 10:29 AM   #5 (permalink)
you're going to put it on top of the that bracket you made??!
that not going to be a bump like the eclipse its going to a HUMP!!!
99cougarsupreme is offline
Old 08-02-2007, 10:45 AM   #6 (permalink)
Destroyer of Dreams
LostRacer's Avatar
seat for circus midgits in the summer time
Wow. want to see how this turns out. You also have the added heat of the engine bay to deal with now. Before, the alt was down the bottom so wen the heat rises it was somewhat ok. but now...I really want to see this work out. Great ideas.. good luck!
The One&Only!
C.A.R.B # FU50
LostRacer is offline
Old 08-02-2007, 11:31 AM   #7 (permalink)
nadthomas's Avatar
Interesting. Keep us up to date on the progress.
2004 5.7L M6 Black GTO - K&N CAI - 18" TSW Indy 500 Staggered - Diablo Tune
2006 2.0T DSG Candy White VW GTI - K&N Drop-In - Headlight Eyelids
nadthomas is offline
Old 08-02-2007, 11:37 AM   #8 (permalink)
Teebs's Avatar
What about relocating the colant resevoir and putting the alt in there? Take alittle more work, probably need to extent the shaft or make a new pulley but I think that would be a better location?
2000 Cougar v6 ATX @ 148, xxx km
Teebs is offline
Old 08-02-2007, 12:00 PM   #9 (permalink)
Teebs's Avatar
Just ran outside to take a peek under the hood... Here's my idea, relocate the colant tank, or make it smaller. Relocate the washer tank, the fill nozzle is in the way. Move some lines around to make some room. You now have a nize cozy spot for an alternator.
Mount the alternator, pulley towards the engine. Mount a second pully onto the crankshaft. Run a belt up to the alt with a tensioner.
I'm not to sure, but it would probably be best to have the alt mounted to the engine correct? Well there's a couple ways I can see it being done... But I'd probably need to draw it...
Another Idea, Relocate the battery, install a CAI or SRI to free up some space, see if you can run an alt over there? You may have more space over there? I don't know.
But for cooling, cut away some of the sheet metal bellow the alt and you can allow some of the air coming in from the front of the car to move across the alt...
My 2 cents...
Teebs is offline
Old 08-02-2007, 12:07 PM   #10 (permalink)
You can buy my supercharger kit and replace the head unit with an alternator which does exactly what is mentioned above.
3L Duratec
