Old 06-13-2008, 03:07 PM   #1 (permalink)
StealthyWeasel's Avatar
Adjusting rev down/idle issues
My car has a bunch of issues.
1) It lopes in idle- done it ever since I got it tuned last year. Sounds like it's cammed.
2) Revs hang sometimes and sometimes they drop REAL fast. Sometimes they'll hang at 1200 until I come to a complete stop, and THEN they go down. A complete stop always brings them down to a normal idle. This has happened ever since I installed a new 65mm TB (done correctly). The only difference is it has no hole in the throttle plate and has a bleeder control on the side of it.
3) Afterfires as loud as a gunshot if I accelerate hard (to around 5600rpm) and press in the clutch or shift. Doesn't do it every time, but frequently does.
4) Throws a P1131 rich code sometimes. The check engine light comes on, goes off, comes on, repeat.
Maybe I need to adjust mixture, and maybe I need to change the "transition from closed to open loop" from 2 seconds to <1 second. I saw BlackCoog mentioning that, seems like it could be relevant. Would the DPFE have anything to do with it? I have no idea what it does.
StealthyWeasel is offline
Old 06-13-2008, 03:08 PM   #2 (permalink)
Re: Adjusting rev down/idle issues
I get about 240 miles a tank driving sanely, that sucks too. Makes me wonder about where all the gas is going..
Old 06-13-2008, 03:22 PM   #3 (permalink)
Karma just kicked ass
wadespencer99's Avatar
Images: 6
I just replaced the EGR Vacuum Canister on the back of the UIM and it seems to have fixed my race car idle. Try that.
CFX 1st Place Mild
wadespencer99 is offline
Old 06-13-2008, 03:51 PM   #4 (permalink)
EDIT: "The vacuum canister sits on the UIM just above the DPFE sensor" (I didn't know what/where it was )
Thanks FastCougar, search button FTW.
That i'm going to try.
Old 06-14-2008, 07:18 AM   #5 (permalink)
SingleShot's Avatar
1,2, and 4 sounds like my car. except I got bank 1 and 2 Lean on the DTC. Any suggestions? I recently did the "Throttle Hang" how to fix where you get the copper cap and drill it. Worked wonders. But I still have a cammed sound (which I like Lol) and some slight throttle hang at 1200.
Wonder if changing the vacuum canister would do anything. Maybe worth a shot.
MySpace <---- Add me
SingleShot is online now
Old 06-14-2008, 07:18 AM   #6 (permalink)
SingleShot's Avatar
Old 06-15-2008, 03:15 PM   #7 (permalink)
mond12345's Avatar
Images: 14
I really think #1 is in the tune some how Josh. Mine car started doing that right after my tune also and we went to the same place....
Heavily Modded
mond12345 is offline
Old 06-15-2008, 07:18 PM   #8 (permalink)
back in the states
how much was the canister and DPFE. i think i have the same problems with mine. but then again i haven't driven mine in almost 2.5 yrs
try a datalog with ur wideband hooked up and see what it looks like....
Old 06-15-2008, 08:37 PM   #9 (permalink)
Images: 6
Nevermind...canister didn't help at all.
CFX 1st Place Mild
Old 06-15-2008, 08:53 PM   #10 (permalink)
ironworker's Avatar
If You Have One Of Those Mity-vac Vacuum Pumps Take The Vacuum Line Off Your Egr Valve While The Car Is Idleing And Hook Up The Pump, And Pump It A Couple Times, If The Idle Doesnt Change The Egr Valve Is Stuck Open And You Need A New One...
ironworker is offline
