Old 04-01-2008, 12:51 PM   #1 (permalink)
turning things off
so I know the xcal is capable of turning things off, where they will register as Not Applicable on a scan tool, such as emmisions sensors.
is there a list of things I can turn off.
basically I need to do my homework on deadpanning sensors to the ECU.
specifically,
seatbelts, door ajars, trunk ajar, bulb failures, HVAC, airbags, anything not critical for running the car.
Old 04-01-2008, 01:41 PM   #2 (permalink)
Correct > Quick
LinkMan's Avatar
Images: 11
Re: turning things off
Curiosity question - Does all of that even go through the ECU? I wouldn't think you'd need to door ajar signals going through ECU, or even seat belt warnings, as that could be something simpler in the instrument cluster.
I'd give the wiring diagram a quick scan if I wasn't sitting at my desk at work. Either way, interesting question and a good thing to sticky once it's answered.
Mark (AIM:LaserRedCat)
1998 T.Red Contour V6 ATX FCO
1993 Bright Red Tempo 2.3 ATX
LinkMan is offline
Old 04-03-2008, 01:34 AM   #3 (permalink)
evilkowz's Avatar
I had the same problem, but more with transmision codes thrown after my swap. The guys at brenspeed said that they couldn't eliminate those codes, so I'm not sure about these.
mah vehicular modual
My car is a born again stick.
BEER IS GOOD, BEER IS GOOD, BEER IS GOOD...AND STUFF!!-Psycostick
me myspace
evilkowz is offline
Old 04-03-2008, 01:52 AM   #4 (permalink)
Redmofo's Avatar
Some arent going to go directly to ECU, will goto other computers thats will then goto ECU. Some I would assume you could not turn off you would have to put in resistors or hard wire connections.
CougarDB
GMprincess: I dont want to be a FRIGID BtICH but c'mon!
5 min later me: I dont want to be a frigid BtICH but Cmon!
I use to OWN a PROBE
Redmofo is offline
Old 04-03-2008, 10:42 AM   #5 (permalink)
is there any documentation on the SCT settings that I could peruse to get a better idea?
Old 04-03-2008, 11:52 AM   #6 (permalink)
someone call a medvac
i wonder if there is any helpful info on the SCT forum.....interesting. all the info i had see n was for the tuning aspect. you going a different route with the xcal2....very interesting
Old 04-03-2008, 12:18 PM   #7 (permalink)
EFFING MOSQUITOS
then they dont know what they are talking about. mine are shut off
BUY COUGARFEST RAFFLE TICKETS
jaged is offline
Old 04-03-2008, 02:33 PM   #8 (permalink)
evilkowz's Avatar
huh...
me myspace
evilkowz is offline
Old 04-03-2008, 05:39 PM   #9 (permalink)
The tranny is basically defined by one scalar value, trans_type. My manual cougar's pcm has transmission pressure and torque maps, shifting times, etc defined, but pcm doesn't read those values when it has trans_type set to manual.
specifically,
From that list, pcm only knows and controls the AC clutch. "anything not critical for running the car" = not pcm related circuits (mostly).
Things that you can turn off are all somehow directly connected to the engine (egr, imrc, ...etc) or things needed to run the engine (cooling fans and fuel pump for example). Pcm doesn't have information about your airbags, seat belts, status of your windscreen wipers, etc.
Dash warning lights are controlled by a few modules together. Remote locking, alarm and double locking are controlled by one module.
ps. Some of the aux warning or control modules can be read and tested with ford tools via the obdii plug. These few modules use different contacts in the connector and doesn't share the real obdii bus or protocol.
kymi is offline
Old 04-03-2008, 10:14 PM   #10 (permalink)
evilkowz's Avatar
So how would I then change my trans type in the ecu, without swapping in a real MTX ecu?
me myspace
evilkowz is offline
