#31 (permalink) |
Re: DTC's came back
...sorry i meant using another stock exhaust system fabricated to make dual pipe system...G.
#32 (permalink) | |
Re: DTC's came back
Something for me to think about if I upgrade some time to a 3.0l ![]()
A Mazda MPV is really only a cougar in family friendly clothing............
#33 (permalink) |
Re: DTC's came back
... Ok back to the thread. I fitted the 19 lb injectors, a new engine harness (injector plug broken on the old one) and port matched the UIM to the lower. I put on the plug wires i bought from cougarguy939 (thanks the're great). I've reset the ECU..so now we wait to see if the P0171/4 codes come back...G.
#34 (permalink) | |
Re: DTC's came back
#35 (permalink) |
Re: DTC's came back
csv... i'll have to look that one up. 48 hrs+ and no codes at all...
G.
#36 (permalink) |
Re: DTC's came back
I think usually two driving cycles, you should also be able to check pending codes as well, in this NGS system I have it has a FD prefix for the item. Not too sure if that is available on the ELM system or not.
#37 (permalink) |
Re: DTC's came back
..ok csv, comma separated values. I've just got the software for datalogging...and my floppy has decided to go on strike
. Anyhow...72 hrs+ and some spirited driving later...no codes at all . Not sure if i had a problem which was corrected during the work...but peace of mind with the injectors and having an UIM ready ported for a GB max extrude is great.. G.
#38 (permalink) |
Re: DTC's came back
I'm coming late to the party, but Joey of Nautilus Performance (a.k.a. BurritaSVT) told me that the OEM MAF maxes out at 35 lbs/min. If you've done the rest of the SVT conversion, it sounds like the 19 lb injectors will work nicely. Good luck!
#39 (permalink) |
Re: DTC's came back
Hi, G
notice in that other thread there was a bit of heat on the codes, the 19lb wont work unless there is something to tune with. With the MAF having so much capacity it means to me that something like a greddy/safc would work fine as an interim, if you don't have a means to flash the pcm. I will say though you need to make sure that there is no intake leak, and that those oem o2 sensors are all good, also that the MAF is ok. But from memory you checked all that. Just check all those intake spots with a spray of brake cleaner to see if there is any leaks at all??
#40 (permalink) | |
Re: DTC's came back
