Old 03-13-2007, 12:28 PM   #1 (permalink)
evilkowz's Avatar
Cooling fans don't run after Xcal install
So I installed my Xcal code, and now my cooling fans do not kick on. Is there a setting for them and it was just set too high? Or did I f something up.
mah vehicular modual
My car is a born again stick.
BEER IS GOOD, BEER IS GOOD, BEER IS GOOD...AND STUFF!!-Psycostick
me myspace
evilkowz is offline
Old 03-13-2007, 02:59 PM   #2 (permalink)
Re: Cooling fans don't run after Xcal install
ummm, when you turn on your A/C do the fans at least turn on low?
I honestly cant say I've ever heard/noticed my fans kicking on high.
I think the temp setting for them kicking on is 180
Old 03-15-2007, 08:35 PM   #3 (permalink)
96blackse's Avatar
There is an option to delete the electric fan signal which the PCM sends using the electrodrive_fan_switch in system switches if this is turned off the PCM won't be giving the signal to get your fans going
Low speed fan usually comes on at 216 degrees
3L 13.5@104 GOT OVAL PORTS? Video of my run!
NEW Ford 4 bolt control arms $105!
NEW GCK axles $65 each!
www.AxlesForLess.com
96blackse is offline
Old 04-23-2007, 10:36 PM   #4 (permalink)
evilkowz's Avatar
I just went in and checked and my temp for low speed is set at 180 and the high speed is 210. But it seems like it consistantly ran b-4 the tune, and now if I'm in heavy traffic for too long I have to blast my defroster to cool the engine. I don't hear the fans kicking on anymore. I was reading the intructions about downloading codes, and it says to unhook the fuse for the cooling fans, which I didn't do, but the fuses look fine.
me myspace
evilkowz is offline
Old 04-23-2007, 10:44 PM   #5 (permalink)
mond12345's Avatar
Images: 14
You don't want your low speed fan so come on at 180, the thing will never turn off.... I have mine set at 200 for low speed and 210 i think for high speed and still to this day i have not heard my high speed kick on yet.
Heavily Modded
mond12345 is offline
Old 04-23-2007, 10:55 PM   #6 (permalink)
evilkowz's Avatar
But why is my car still overheating?
me myspace
evilkowz is offline
Old 04-23-2007, 11:10 PM   #7 (permalink)
Make-U-C2's Avatar
Check your Cooling Fan Relays usually it is suggested that you change those when you change your fans, its like putting an old lightbulb in your house.....
"There Is Nothing Wrong With Me A Little Money Won't Change" -Scrapomatic
Make-U-C2 is offline
Old 04-23-2007, 11:15 PM   #8 (permalink)
J-Man's Avatar
So your car overheats when you are standstill. What temp does it get to when sitting?
"How a politician stands on the Second Amendment tells you how he or she views you as an individual... as a trustworthy and productive citizen, or as part of an unruly crowd that needs to be lorded over, controlled, supervised, and taken care of." -- Representative Suzanna Gratia Hupp (TX)"
J-Man is offline
Old 04-23-2007, 11:21 PM   #9 (permalink)
evilkowz's Avatar
Not sure, I can't seem to get my xcal live link to work, It keeps freezing up. Whenever I try to select paramiters it brings up a thing that says to choose what parameters, but nothing is listed and I can't click out of it.
I will try the relay. And also I will tune the low speed back to 200.
me myspace
evilkowz is offline
Old 04-23-2007, 11:22 PM   #10 (permalink)
mond12345's Avatar
Images: 14
Check the fan fuse and relay first, than make sure the fans themselves are plugged in.
Heavily Modded
