Old 11-29-2006, 12:31 PM   #1 (permalink)
Gorman's Avatar
com port or USB
Hi Guys; for data logging purposes...will the com port be quick enough or is USB a must. Does it depend on the laptop ? I read the com port type are unreliable...is that true ? Just looking to start monitoring the ecu with with an old laptop under then seat. cheers BigG
Gorman is offline
Old 11-29-2006, 12:42 PM   #2 (permalink)
Re: com port or USB
speaking only from a computer aspect, serial ports are much more reliable than USB [in fact if it offers you the choice, the USB is almost certainly using serial port emulation anyways].
a serial port is relatively slow for transfering data and I'm not sure how much data is really transfered with the data loggers but I can only guess that it is well within the abilities of a serial port.
Old 11-29-2006, 12:55 PM   #3 (permalink)
Gorman's Avatar
Re: com port or USB
Cheers for that T. "a serial port is relatively slow for transfering data and I'm not sure how much data is really transfered with the data loggers but I can only guess that it is well within the abilities of a serial port." Anyone have any idea of data rates and how big files can get over say a week ? Thanks G.
Gorman is offline
Old 11-29-2006, 06:17 PM   #4 (permalink)
DemonSVT's Avatar
Re: com port or USB
Well answered already.
A serial port is very limited in the amount of total polls per second it can log. (i.e. transfer rate) Expect to be able to log 5-6 categories at multiple polls a second. Anything slower then this is not worth datalogging. This port is very reliable and consistent.
A USB interface does not have this limitation but is also less reliable/consistent.
I've had no problems datalogging with Alex Pepper's OBD-II setup and it uses a serial port connection.
My 2000 SVT Contour
13.47 @ 102mph - All Motor
DemonSVT is offline
Old 11-29-2006, 06:47 PM   #5 (permalink)
Re: com port or USB
ya, I was all excited, its probably going to be the only question in the tuning section I will ever be able to answer.
Old 11-29-2006, 07:24 PM   #6 (permalink)
Gorman's Avatar
Re: com port or USB
Thanks DSVT; for the clarification; 5 or 6 parameters will probably do, to start with. I can't imagine the data; over a week, would overflow the 20G hard drive....unless someone knows otherwise. cheers G.
Gorman is offline
Old 11-29-2006, 07:27 PM   #7 (permalink)
Re: com port or USB
no it wont get anywhere close to that.... and if it does, you'll have more data then you'll ever be able to analyze
Old 11-29-2006, 07:39 PM   #8 (permalink)
Gorman's Avatar
Re: com port or USB
Hi T. i was hoping to check out the A/F ratio and see if I'm running rich/lean thru the rev. range...the motor rev's OK, but it seems to lack real urgency. First step then..get connected... cheers G.
Gorman is offline
Old 11-29-2006, 08:03 PM   #9 (permalink)
Re: com port or USB
no, keep us posted, I'm going to be picking up some datalogging equipment in the next few weeks so it will be nice to know answers to these questions also [that and the laptop I'd be using only has a 850meg hd]
Old 11-30-2006, 04:52 AM   #10 (permalink)
cpapashley's Avatar
Re: com port or USB
Oh how I wish it was that simple for me.....
But please post some details. I think it will be full of surprises
Will be looking on with interest.
cpapashley is offline
