Missing 2 bolts Need to know what they hold in!
Results 1 to 7 of 7
Thread: Missing 2 bolts Need to know what they hold in!
    1% Moderator iceberg65's Avatar
    2007 Apr
    Medicine Hat, AB
    2,894
    Hey guys, I'm posting this out of my build thread in the zetec section in hopes to get a bit more traffic from the trans guru's......its a long story.
    What do these bolts hold? and how long should they be? I need to know If I'm gonna be able to re-allign em, and put in new bolts without wrecking anything.
    a couple pics: note that these are right beside the fill plug (obviously)
    The ONLY Supercharged Zetec Cougar!
    TZT Performance Gold MemberModerator Turbo Zetec Tour's Avatar
    2007 Sep
    Louisville, Kentucky
    3,117
    Re: Missing 2 bolts Need to know what they hold in!
    Ill post this here as well but i already responded in your build thread.
    they look like they are for the bracket that holds the reverse idler gear.
    Daniel - TZT Performance
    2000 Black SVTC #391 - sold
    NECO Member MidOH3LCougar's Avatar
    2011 Jan
    Cardington, OH
    1,020
    ^^ x2, posted a couple pics in your thread, have bolts for you or can measure them.
    2007 Apr
    Medicine Hat, AB
    2,894
    If you happen to be in your shop with the bolts at hand a measurement would be helpfull. I should be able to figure it out.
    thanks guys; now that I know what I'm dealing with I should be able to get this figured out.
    2011 Jan
    Cardington, OH
    1,020
    Its a shouldered bolt with a 10mm head.
    Thread size and pitch im unsure.
    But the threaded area is 25mm (1") long.
    2007 Sep
    3,117
    well damn, i was close then. threads are probably an M8 x 1.25
    2007 Apr
    Medicine Hat, AB
    2,894
    Perfect.
    now I have to find some time to dig into my crate full of parts
