SVT Clutch KIT hunt
Hey guys. I really want to find the SVT clutch kit. I've been on Teamford but the only thing that I see is regular SVT Clutch parts sold seperately. How do I go about getting the entire KIT? Including the SVT flywheel. And for those of you who know, does the SVT flywheel and OEM Stock flywheel differ a lot? As far as weight goes I guess?
OH, don't you make me downshift.......*VROOOOM*
Re: SVT Clutch KIT hunt
call teamfordparts and order it. was about $250 the last time it was listed.
here is the part number for the kit: f7rz7l596ea
Secretary of the Inferior
The kit comes with a clutch disc, pressure plate, and slave cylinder. The flywheel is sold separately. The SVT flywheel is lighter than the standard Duratec flywheel by a little, but the Fidanza and Spec flywheels are lighter still.
So, for $387 shipped I got a SVT flywheel (inclu ring gear), disc, pressure plate, throw out bearing, and align tool. Wheee...
Looks good! not a bad price either
what flywheel you going with?
![]() Previously 99mcougar Cougardb Cardomain FS: Pro-M, OEM Springs In The Mail: 19" Centerline RPM's with Toyo Proxy Tires. Waiting for Install: 94A polly filled front roll resistor. |
SVT. I figured I couldn't go wrong there. It was actually cheaper than the standard flywheel so I figured that was a no brainer. $123.27 for the flywheel.
You know guys, the flywheel that I got has 10 holes around the center where it bolts to the crankshaft. But only 2 of them are threaded and they are offset a little bit from the rest? Is that normal? I've never seen one like that.
That's so it goes on the same way every time.
