Old 06-04-2008, 10:11 PM   #1 (permalink)
Serious tranny problem MTX
I can't get into 2nd, 4th, and reverse on my shifter anymore. How do I fix it? I was installing a new short throw shifter and now I can't even get into those gears on the stock one.
Is there something that I can do?
tasteypaste is offline
Old 06-04-2008, 11:58 PM   #2 (permalink)
Platinum MemberModerator
DanG's Avatar
Re: Serious tranny problem MTX
Moving to the Trans forum. Good luck- I believe you've popped a shift cable out, 'cause it appears your lower gate isn't opening...
Dan G.
DanG is offline
Old 06-05-2008, 09:24 AM   #3 (permalink)
brapple's Avatar
i don't think that the linkage came off if you can get the rest of the gears. sounds like the cable are out of adjustment.
- 95 Mystique LS Zetec 5-spd
- 2k Contour SVT - #2137
brapple is offline
Old 06-06-2008, 09:40 AM   #4 (permalink)
As mentioned above there must be an issue with your cables. You can get access to them if you pull your driver's side wheel off. They are on the back of the transmission toward the top.
Old 06-06-2008, 01:58 PM   #5 (permalink)
Topik's Avatar
Possible the grommet for the cable is completely gone and popped the cable off. Seen it a couple times on these cars.
Barack the c*nt hunter
402whp
379 ft lb.
1999 3l turbo cougar
1998.5 Sh*tVT contour #3162
Topik is offline
