#21 (permalink) |
Re: 6 speed transmission.
Well Shipping won't be an issue then
![]() You could check Cheap car parts, Engines & 4x4 Parts. Find used car parts & car spares from online car breakers for parts.... thats how I found my ST220 UIM, then found someone to help ship it over since no place wanted to deal with it. Adding a 6spd or AWD would be easier for you, still not easy obviously, but at least there isn't the huge shipping hurdles to get the parts. |
#22 (permalink) |
well; if you guys want parts shipped over...i could double check to see if the shipping costs you are being quoted are over the top...lmk...G.
#23 (permalink) |
Okay so would this hole process would be possiable to do to an automatic?
cause i know you can swap to a manual with some hard work and a know how about what your doing.
![]() ~ 99 Mercury Cougar ATX ~ SPONSORED ![]() http://www.carsponsors.com/profile.php?id=381793 |
#24 (permalink) | |
om nom nom nom!
600.....my god that's cheap. I paid significantly more for an 06 wrx 5spd with 13k on it. The STi 6spd was even more but it's worth every penny. Is that 6spd any stronger than the 5?
6spd Bugeye #555|SM
#25 (permalink) |
first of all, i don't think an ST220 box is in the same league as an STi box. Second, i don't think the 6 speed is any stronger....it just keeps you in the powerband without having to rev the thing to the limit to keep the rev's up in the next gear...G. btw..i've contacted terry haines...awaiting a reply.
#26 (permalink) |
I don't correctly recall the ratios in the 220 box but I don't remember the gear spacing being much tighter than the MTX75. You most likely gain a taller overdrive and closer 4th and 5th.
FWIW, I think a better return on investment would be to clock the engine 90* or look about a Jag powertrain as even with six gears you're still stuck with FWD.
#27 (permalink) |
Durashift Six Speed Manual Transmission (For Duratec SCi and Duratec V6 models) Gear Ratios 1st 3.231 2nd 2.048 3rd 1.423 4th 1.129 5th 1.029 6th 0.886 Reverse 1.360 Final DriveSet 4.357 (1/2/3/4) 3.050 (5/6/ rev) Durashift five-speed manual transmission ST220 MTX75 Gear Ratios.... 1st 3.417... 2nd 2.136 ...3rd 1.483 ...4th 1.114 ...5th 0.902 ...Reverse 3.620 ...Final Drive 3.560 can anyone do the math....revs after shift at 6750rpm in each gear....G.
2.5L MTX. SVT ECU. Cold air feeds. 65mm P+P TB. Port matched SVT upper to SVT LIM. MSDS Headers. Optimized Y pipe. Test pipe. Wish list. 4X4 wtb xcal Last edited by Gorman; 05-22-2008 at 05:28 PM. |
#28 (permalink) | |
I spoke with TH about the 6 speed..he said it fits..it requires modified mounts ( which he has) and that he can make it work !... so the search for a box and diff is on....G.
