Old 05-01-2008, 08:26 PM   #1 (permalink)
tranny kicked out the half shaft....
i got a new half shaft.. got it installed... drove for 30 meters...
the entire tranny case cracked all the way around.. (N)
any one have similar problem?
mohamed_mourad is offline
Old 05-01-2008, 11:18 PM   #2 (permalink)
Platinum MemberModerator
DanG's Avatar
Re: tranny kicked out the half shaft....
dude.
Who installed it? Time to go hold them to account.
If you did it, time for a new transaxle. Car-part FTW.
Dan G.
DanG is offline
Old 05-02-2008, 06:57 AM   #3 (permalink)
brapple's Avatar
that is very weird ...I had the half shaft pull out of the trans last weekend while cruising down the higway, the nuts holding it to the bracket came off. no damage done. slide the half shaft back into the trans and added fluid and was good to go ...
- 95 Mystique LS Zetec 5-spd
- 2k Contour SVT - #2137
brapple is offline
Old 05-02-2008, 10:05 AM   #4 (permalink)
What side was it? Driver side or passenger side? What was wrong with the previous one? Your diff may have been bad in the first place and then finally blew up when you put the new shaft in.
1998 SVT Contour, ported 3L
1999 SVT Contour, stock
http://www.3lduratec.com For info on our new supercharger kit coming out very soon.
Old 05-08-2008, 11:30 PM   #5 (permalink)
IM NOT YOUR GUY, BUDDY!
Topik's Avatar
yeah whoever installed it cracked the case chances are unless the diff exploded like stated.
1999 3l turbo cougar
1998 SVT Contour #3162
Topik is offline
Old 05-09-2008, 12:02 AM   #6 (permalink)
IdealProductz's Avatar
someone else installed it= there accountable
you installed it= headache
IdealProductz is offline
SEO by vBSEO 3.1.0
