Old 03-25-2008, 07:24 AM   #11 (permalink)
brapple's Avatar
Re: turbo engine how should i build up my trany
Originally Posted by DanG View Post
gamiller speaks the truth. The lightened flywheel makes the Duratec "twitchy" during shifts, and even during throttle braking or deceleration due to the decrease in rotating mass. While a lightened flywheel "frees" up power by removing extra mass the engine has to spin, it makes for less "friendly" daily use. F/I will only exasorbate this behavior.
this is the reason why I only went with a SVT flywheel in my swap .... but the built HMS MTX that I got had the coated gears, quiafe, new shift forks, etc. I would go for everything.
- 95 Mystique LS Zetec 5-spd
- 2k Contour SVT - #2137
brapple is offline
Old 03-25-2008, 10:12 AM   #12 (permalink)
-CRAZY-'s Avatar
guys, quick question. u have turboed 3L engines, which are quite powerful, have u ever though of changing gear ratios?
-CRAZY- is offline
Old 03-25-2008, 10:16 AM   #13 (permalink)
boarder4life's Avatar
that would be the "final drive", its a common practice but im not sure if anyone here has actually done it.
boarder4life is offline
Old 03-25-2008, 10:30 AM   #14 (permalink)
SlowCat's Avatar
You can also buy an entire gear set with different ratios from quaife i think.... but it'd be expensive as ... well you get the idea.
SlowCat is offline
Old 03-27-2008, 10:04 PM   #15 (permalink)
-CRAZY-'s Avatar
yeah.. i see... lol good to know...
-CRAZY- is offline
