Sloppy shifter
Hi! i own a 99 cougar 4 cyl mtx and the shifter is VERY sloppy. I'll be in third and can move it in all four directions about an inch without it popping it out of gear. and the same goes for all gears although not as severe as 3rd. I am not sure if this would be the bushings or the shift cables, etc. any help would be appreciated.
Re: Sloppy shifter
most likely its the bushings on the cable ends.
Secretary of the Inferior
Re: Sloppy shifter
The shifter is held into the shift tower by a retaining plate on the top. YOu can easily see this when you remove the shift boot. There are sometimes 2, sometimes 4 torx-head screws that hold the retaining plate down, keeping the ball of the shifter solidly in place. These screws are known to work themselves loose after time, causing the situation you are experiencing right now.
Re: Sloppy shifter
great point, I forgot that those bolts sometimes come loose. definately worth checking out also.
Re: Sloppy shifter
is that what your problem ended up being?? I remember you asking about cables not too long ago.
1999 MTX, 3.0, silver frost SVT UIM,LIM,CAMS,TB,INJECTORS,ECU,CLUTCH. AEM-GMK. MSDS-TRUBENDZ-MAGNAFLOW. FIDANZA. B&G-KYB-JAGED RSTB. ADR. ALPINE. 215HP, 191TQ AIRCOUGAR PERFORMANCE
#7 (permalink) | |
Destroyer of Dreams
Re: Sloppy shifter
Yep. I removed the boot to check on the cables only to find two bolts sitting above the plate.. Tightend them up and I was good to go I'm such a noob. ![]()
The One&Only! C.A.R.B # FU50
Re: Sloppy shifter
yeah same things happend to me! it got so bad that i couldn't get it into first gear lol
"If you're not first, you're last" ....Ricky Bobby ![]() GFX By TheWingsER CarDomain Profile |
#10 (permalink) |
Re: Sloppy shifter
probably autozone or better yet Bill Jenkins @ teamfordparts.com. Let him know ur from NECO.
2002 Cougar XR 1985 Mazda RX-7 GSL 1931 Chevy -for sale. 2007 Dodge Caliber |
