Clutch bolt torque
Hey guys,
I am installing a new clutch on my car, and was curious what do I torque the bolts to holding the pressure plate on? Also, how do I know if the clutch is centered or not? I used the centering tool, but it has a little slop in it. I tried holding it and eyeing it so hopefully its right. Also, I got the lightweight flywheel with about 17k on it, should I get the new insert for it before continuing with the clutch project? The flywheel feels really smooth if that makes a difference. Thanks, Bill
1998.5 3L Hybrid SVT Contour w/ nitrous...etc 220 WHP without spray. Last edited by starjammir; 02-05-2008 at 03:41 PM. |
Re: Clutch bolt torque
I dont have the manual handy for torq specs but, with the centering tool just try to center it with your eye as best as you can...
Its also a good idea to get a newfriction plate
3L 13.5@104 GOT OVAL PORTS? Video of my run!NEW Ford 4 bolt control arms $105! NEW GCK axles $65 each! www.AxlesForLess.com |
The clutch to flywheel tq isn't very much from what I remember. I was thinking 10ft-lbs but check the manual to be sure. Use locktite on them.
#5 (permalink) | |
2000 Cougar V6 1993 Ford Aerostar (Mass People Mover) 1992 Nissan Maxima (4DSC daily driver) 1988 Ford Aerostar Cargo (parts hauler and tow vehicle) |
#6 (permalink) | |
Yes, the bolts are completely re-usable.
#7 (permalink) | |
shoult had it right- If it's close, the trans will mate to the engine, and the first press of the clutch pedal will center it the rest of the way as the pressure plate releases the force on the clutch disc.
If the clutch wasn't centered correctly the input shaft on the transmission wouldn't go into the clutch so your transmission wouldn't bolt together. It doesn't have to be absolutely perfect which is why the tool has so much slop.
#10 (permalink) | |
![]() Wait- Did that come out wrong? ![]()
