Old 01-31-2008, 05:14 PM   #1 (permalink)
AndrewM6097's Avatar
Flywheel Insert
I just purchased a used SPEC flywheel and i would like to replace the friction insert.... Can someone confirm that the fidanza insert will work with the SPEC flywheel??
1999 MTX, 3.0, silver frost SVT UIM,LIM,CAMS,TB,INJECTORS,ECU,CLUTCH. AEM-GMK. MSDS-TRUBENDZ-MAGNAFLOW. FIDANZA. B&G-KYB-JAGED RSTB. ADR. ALPINE. 215HP, 191TQ
AIRCOUGAR PERFORMANCE
AndrewM6097 is offline
Old 02-01-2008, 12:54 AM   #2 (permalink)
You Got Rondo'd!
aircougar1's Avatar
Images: 1
Re: Flywheel Insert
I am pretty sure that the flywheels are made by the same company, so the Fidanza insert replacement, should fit without a problem...
I have a Fidanza flywheel in the basement as well as the SPEC I sold you... I can look to see if everything is the same when you come pick up the parts...
Just remind me.
"YAHTZEE!!!!"
1999 Laser Red Cougar Mtx
aircougar1 is offline
Old 02-05-2008, 09:29 PM   #3 (permalink)
96blackse's Avatar
Re: Flywheel Insert
Fidanaza flywheels = Spec flywheels
So yes the friction plate will work
3L 13.5@104 GOT OVAL PORTS? Video of my run!
NEW Ford 4 bolt control arms $105!
NEW GCK axles $65 each!
www.AxlesForLess.com
96blackse is offline
Old 02-06-2008, 02:30 PM   #4 (permalink)
starjammir's Avatar
Re: Flywheel Insert
Do you have to remove the flywheel to replace this insert? If so, are the nuts that hold the flywheel on, one time use?
Thanks
1998.5 3L Hybrid SVT Contour w/ nitrous...etc
220 WHP without spray.
starjammir is offline
Old 02-06-2008, 03:10 PM   #5 (permalink)
Re: Flywheel Insert
i think i read that the the new insert also comes with new fastners
Old 02-07-2008, 12:27 AM   #6 (permalink)
96blackse's Avatar
Re: Flywheel Insert
Yes you need to remove the flywheel... Just make sure you are using the right screwdriver because its easy to strip while tightening... New hardware is included... I use a small ratchet with a screwdriver bit much easier to torque down the screws
Old 02-11-2008, 06:34 PM   #7 (permalink)
Re: Flywheel Insert
Just put the new plate on down in the basement, very easy. Torqued all the nuts to 5lbs. 5lbs doesnt seem like much but thats what the instructions say so i guess i'm good.
Old 02-16-2008, 09:56 PM   #8 (permalink)
sheldon729's Avatar
Re: Flywheel Insert
I just replaced mine and i used my air ratchet at my shop with a thin walled 3/8 socket i believe the size is...Also make sure both mating surfaces are clean. Those bolts are only torqued to 45in.lbs/5ft.lbs
BEFORE!
AFTER
sheldon729 is offline
Old 02-17-2008, 01:01 AM   #9 (permalink)
Re: Flywheel Insert
wouldnt 5 foot pounds be 60 inch pounds?
Old 02-18-2008, 05:13 PM   #10 (permalink)
StealthyWeasel's Avatar
Re: Flywheel Insert
yup
StealthyWeasel is offline
