Old 01-07-2008, 05:56 PM   #1 (permalink)
StealthyWeasel's Avatar
"B1" vs "A" MTX-75
why not..
MTX-75-A (US/NA CDW-27 MTX)
Manual, Five Speed
Max Input Torque: 250 Nm (184 Lb-Ft)
1st: 3.42 (37mph, 39mph)
2nd: 2.13 (59mph, 63mph)
3rd: 1.45 (87mph, 93mph)
4th: 1.03 (123mph, 131mph)
5th: 0.77 (164mph, 175mph)
Reverse: 3.73 (34mph, 36mph)
Final: 4.06 (V6) , 3.82 (I4)
Overall Weight: 46 Kg (101 Lb)
MTX-75-B1 (European CDW-27 MTX)
Manual, Five speed
Max Input Torque: 250 Nm (184 Ft-Lb)
3rd: 1.48 (85mph, 91mph)
4th: 1.11 (114mph, 121mph)
5th: 0.86 (147mph, 156mph)
Reverse: 3.46 (36mph, 39mph)
calculations done w/ 6850rpm max engine speed and 215/55/16 tires. I also assumed the vehicle will have the power to attain such speed..
Source: FFClub > Все про движок 1.6 Ti-VCT (115 л. с.) (translated by google, numbers were the same though)
There's also other versions on the chart of the MTX-75 that i've never seen, ratio wise.
buckeyesvt posted some results with the carsoft performance meter.. I was going to enter my dyno and compare the performance differences regarding the A / B1 gearset, and final drives. The link was down though, does anyone have access to that program? (as seen in this thread)
StealthyWeasel is offline
Old 01-07-2008, 06:13 PM   #2 (permalink)
Re: If you're interested, "B1" vs "A" MTX-75
So with a 0.77:1 fifth gear and a 3.82:1 FD (fastcougar's turbo 3L) the car could go 202mph (yes, an insane notion) with a 7900rpm rev limit and stock 215/55/16 tires
Old 01-07-2008, 08:30 PM   #3 (permalink)
handyandy's Avatar
Images: 7
Re: "B1" vs "A" MTX-75
1999 MTX 3L
Are you looking for something like this?
Speed/RPM Calculator
handyandy is offline
Old 01-07-2008, 10:11 PM   #4 (permalink)
Platinum MemberModerator
DanG's Avatar
Ummm... Not true.
Dan G.
DanG is offline
Old 01-07-2008, 11:14 PM   #5 (permalink)
Images: 743
Originally Posted by DanG View Post
Ummm... Not true.
I concur
As you can see in my dyno video, I can reach 150+ in 4th gear thanks to a non existant rev limiter. Based on my calcs, the most my car could see is roughly 190-192 MPH and that includes factoring in drag AND current hp/tq levels AND a 7,500 RPM limiter ... most calculators don't factor in drag. Kinda pointless since I don't have a road long enough to try it out on and I wouldn't if I did unless the car was caged and it where in some place like Bonneville.
FastCougar is online now
Old 01-08-2008, 01:23 PM   #6 (permalink)
There was a 99 EX turbo civic with a stock body that went 199.3 @ the salt flats, turbocharged b18, ~320wtq. I would want to think you could beat that civic
Old 01-09-2008, 04:26 AM   #7 (permalink)
azbobbybooshay10's Avatar
Images: 6
Cougarfest: Bonneville anyone?
Cougar now in Winter hibernation
2008 V8 Supercar Championship Standings (After Round 12 of 14, Desert 400 @ Bahrain Circuit)
1. #88 Jamie Whincup - Team Vodafone BF Falcon......................................2916
2. #5 Mark Winterbottom - Ford Performance Racing BF Falcon......................2729
3. #1 Garth Tander - Holden Racing Team VE Commodore.............................2624
NEXT RACE: Tasmania Challenge @ Symmons Plains, November 21-23, 2008
azbobbybooshay10 is offline
Old 01-11-2008, 04:22 PM   #8 (permalink)
Images: 743
with a 10,000 RPM limit no doubt ... I could always raise my limit ... keep in mind, my calcs are based on a 7,500 RPM limit.
Old 01-12-2008, 01:48 PM   #9 (permalink)
Oh my god, could a duratec spin higher than 8500?
Old 01-12-2008, 04:46 PM   #10 (permalink)
Images: 743
Test it and let us know what happens
