Old 12-24-2007, 07:15 PM   #1 (permalink)
sheldon729's Avatar
Clutch Chatter!!
Does any one know what part of the clutch makes the chattering noise?
sheldon729 is offline
Old 12-26-2007, 12:35 AM   #2 (permalink)
sheldon729's Avatar
Re: Clutch Chatter!!
no one knows the genreal area?
Old 12-26-2007, 12:55 AM   #3 (permalink)
kanistre's Avatar
Weak springs in the clutch plate itself will chatter. Failing release bearing can make a chattering noise as well.
kanistre is offline
Old 12-26-2007, 11:51 AM   #4 (permalink)
Redlineracer12's Avatar
What kind of clutch are you talking about? Many aftermarket clutches will "chatter" from day one, and it's normal. It is also referred to as gear rollover noise. I'm not sure this is what you're referring to or not.
99 Coug V6 MTX Spruce Green
SVT "Heavy" swap finshed!
CSVT #1321/2150 Born on 1/6/00
213.5whp
Redlineracer12 is offline
Old 12-28-2007, 08:40 PM   #5 (permalink)
sheldon729's Avatar
Its a spec clutch and i know it normal for it i just want to kno what dumb part is making the noise and no its not the roll over or release bearing..The noise is anyoing lol some days it makes me wanna go back to my stock or try a different brand out :p
Old 12-29-2007, 05:11 PM   #6 (permalink)
sheldon729's Avatar
I hate that gawd dam clutch chatter why cant spec fix that problem!!! you think they would because its annoying im going to email them directly and see what the hell they were thinking
Old 01-07-2008, 03:42 PM   #7 (permalink)
I'd say almost every single spec clutch chatters, which is why I always recommend the stock SVT clutch for those looking at NA power levels. My 3+ spec clutch hasn't had the chatter issue so I've been lucky so far.
Old 01-07-2008, 03:49 PM   #8 (permalink)
Pompous Libtard :)
BigBalledOX's Avatar
Images: 51
You spend a lot of time with the clutch pedal depressed or are you just that much of a whiner? The only time I've ever had any clutch chatter is when the clutch is disengaged.
Basically, Kraft Dinner is to Canadians what fried chicken is to black people, or rice is to Asians, or *insert other stereotype here*
its a money pit!
BigBalledOX is offline
Old 01-07-2008, 11:46 PM   #9 (permalink)
I feel his pain though. I'm using an SVT clutch and no chatter here, but I've bought several other products and upon receiving them I was disapointed.
It just sucks to buy new parts and find out they have issues that the manufacturer didn't mention.
I've come to learn that once you start modding a car heavily you will always get some kind of little "quirks" and nothing will be the same.
1999 Laser Red MTX
14.509 1/4 2.265 60'
RodneyBur is offline
Old 02-04-2008, 03:15 PM   #10 (permalink)
99CougTRX's Avatar
This thread is kinda dead but I have this same problem. It only does it as I'm slipping the clutch rolling into gear...It's kind of annoying and I feel like it shouldn't do it. Should I see about clutch replacement? I would get a SVT clutch and flywheel...the car has 98,500 miles so that's really good for an OEM clutch. I don't experience any difficulty shifting or anything other than the chatter, but it'll have to been done sooner or later, doesn't matter. Sometimes it does wanna pop outta first on me though, very rarely that could be a synchro right?
OH, don't you make me downshift.......
*VROOOOM*
99CougTRX is offline
