Wheel bearing or replace whole axle.hub assembly?
Results 1 to 4 of 4
Thread: Wheel bearing or replace whole axle.hub assembly?
    Buyer Beware GrandMasterKhan's Avatar
    2002 Aug
    6,575
    Which would be easier to do? Simply remove the knuckle and have the bearing pressed in?
    or knock out the axel and replace the entire assembly? Hub, knuckle & CV?
    Originally Posted by Clutch
    "repost from turbomustangs thread, jesus can you not check the whole internet before you post something??? What the hell is wrong with you?"
    Parting out my cougar!
    "Square pistons rock..." -DemonSVT
    GMK full systems no longer available. GMK CAI Extensions available by special request only.
    That link is NSFW Lifetime Platinum MemberModerator bensenvill's Avatar
    2003 Aug
    Chicago
    14,377
    Re: Wheel bearing or replace whole axle.hub assembly?
    I'm assuming your talking front knuckle assembly.
    its going to be easier [if not cheaper] to pull the knuckle and take it to a shop to have a new bearing pressed in
    I just started hemorrhaging blood from the sheer amount of rage that suddenly built up inside me from that comment.
    1994 Lincoln Towncar w/ 112576 CRUSHED
    1996 Contour SE MTX loaded w/ 137179 CRUSHED
    1999 Silver Frost MTX original owner w/ 70500 ALMOST RUNNING
    2009 Honda Fit manual w/ floormats
    NECO Member Ludwik's Avatar
    2005 May
    41
    It's not easier or harder to do either.
    When you buy a hub from FORD they come with the bearing already pressed in.
    Just pull off your hub and go talk to a mechanic at FORD. If you have a friend who works there even better , I got a brand new OEM bearing from FORD pressed in for 20 dollars canadian, that's WITH the bearing too. (like a 3 dollars american right? LOL)
    It takes aprox 10 min from handing it to the mechanic to receiving it back into your hands.
    The HARDEST part... is actually getting to your destination where they will be pressing in your bearing...
    15.60 @ 88
    Borla exhaust from trubendz with cat
    My tires are bald with cracks.. my clutch slips like theres no tomorow... And I still love my cougar...
    2002 Jul
    Louisiana
    725
    I would just replace the bearing i replaced one of mine a while back its not that hard. You just have to bring it to a shop to do the pressing then go back home and put it back togeather. I believe some aftermarket bearings have lifetime warrantys but i could be wrong. I guess it just depends on how cheap a new knuckle from ford was if it were 30-50 bucks i would get the new knuckle anything more and i would just get the new bearings.
    Jameson
    2000 DTG MTX 3.0 ,SVT CAMS,UIM,LIM, & TB, Bassani Catback, Eibach Springs, Mirko RSTB, Front STB, Quaife LSD, Centerforce Clutch, Fidanza Flywheel, 18" Oz Superleggera's, Baer Brake Kit, StangKiller F&R LCA's, PRT Mounts, S.S. Headers
  1. Hub/Bearing Assembly
    By japgar01 in forum Problems
    Last Post: 2008-02-21, 02:09 PM
  2. Question on Hub assembly & bearing
    By CbOy2000 in forum Suspension Performance
    Last Post: 2006-04-06, 03:35 AM
  3. WTB: brake rotor, wheel bearing, wheel hub, ad nauseum
    By gamiller in forum Capital NECO
    Last Post: 2003-01-15, 07:34 PM
  4. FYI : Broken steering knuckle, hub assembly, and disintegrated wheel bearing
    By TwistedXzibits in forum Wheels,Tires & Brakes
    Last Post: 2002-09-13, 06:32 PM
  5. Snapped the ball bearing in the front axle assembly
    By Ten27Cougar in forum Problems
    Last Post: 2001-06-01, 12:44 AM
