#32 (permalink) | |
Re: Suspension FAQ (Read This First)
FYI, Bradness @ CEG makes tubular toe arms, boxed main arms, and subframe connectors. He also makes a torque brace he calls the "Street Link" which replaces the stab-o-shock installed on the SVT Contour between the motor and the tranny.
#33 (permalink) |
I just ran across these, I don't think they have been mentioned before.
Granatelli Motorsports Coil Over Kit [Part#: GMCO7998RR] |
#34 (permalink) |
Anybody know what type of grease is best for the sway bar bushings? I've heard people use white lithium grease, but that doesn't last long enough.
#35 (permalink) |
F5RZ 18198 is supposed to be the strut mount part number. But when i order my parts from a ford dealership i got F5RZ 18198 AA. Will these work? They look like the part in the picture but i just want to make sure.
01 Dark Shadow Grey Ford Cougar w/ Flowmaster, taillight covers, smoked sides, For Sale: Z3 Fenders, Full Body Kit, 18" Gunmetal Motegi MR3s http://www.cardomain.com/ride/578111 |
#37 (permalink) |
ok good i was hoping thats all it was and i didnt need to reorder parts. now i can proceed to the lowering
#38 (permalink) |
Bolt Sizes
JScullin posted the bolt head sizes in another thread, but I thought I would add the bolt sizes and threads, which is handy if you need to replace a bolt, nut, or clean up the threads on your existing bolts and nuts with a tap-and-die set.
M12 x 1.75 Ball joint pinch bolt Strut pinch bolt M12 x 1.25 Strut top M10 x 1.5 Brake hose brace Endlink ends Tie Rod
#39 (permalink) |
Whenever I go to AutoZone to borrow the tools needed to replace the half-shafts, the clerk fails to find them in the computer and denies that they exist, so hopefully this will prevent that problem for you all:
Top Row Tie Rod Splitter OEM27022 32mm Socket OEM27051/OEM27053 Flange Axle FWD puller OEM27037 Middle Row Breaker Bar (Optional but helpful) Bottom Row Slide hammer OEM27033 FWD axle puller adapter (attached to slide hammer) OEM27022 ![]()
