#22 (permalink) |
Re: Suspension FAQ (Read This First)
at the eibach page they only say 98-2000
![]() Mods: MG Body Kit with Roush Side Skirts, Dual Cat-Back Exhaust, Intake, Ciggy Plug, IMRC Relocation, Tail-Light Covers, Shorty Antenna, Escape Oil Pan, Clear Side Markers, Akuza 18's with Nankang Tires, and a T-Top Sunroof ![]() CARDOMAIN |
#23 (permalink) |
Got turbine on my mind
i'd like to see some mention of other suspension parts with a description, list of manufacturers, and comparison:
* strut tower braces * rear strut tower braces * subframe connectors * boxed/tubular control arms
#24 (permalink) | |
THE NECO Newfie
ditto. I've been out of the suspension loop for the last couple years... I've heard of these, but know very little about them.
2001 V6 2.5L MTX Cougar ![]() Injen/GMK/Borla/Koni/GroundControl/ST200/OMP/BAT/Aerogear/Velox/NicheAudio Craig Lieberman from 'The Fast and the Furious': "F&%k that's loud!" CougarDB Profile |
#25 (permalink) |
yeah i believe the only thing you have to change on the 01-02 cougars are the rear strut mounts to get that to work.
2002 Cougar XR 1985 Mazda RX-7 GSL 1931 Chevy -for sale. 2007 Dodge Caliber |
#26 (permalink) |
EFFING MOSQUITOS
REAR STRUT TOWER BRACE (RSTB)
- there are a couple braces out there, -ST200, designed by Ford, The ST200 has an added "X" brace that adds stiffness. made of aluminum -Mirko, aluminum bar from tower to tower. -Jaged, made by me is a steel bar that goes from tower to tower.-Fast Track, made by ov3n and Cougar GT(iirc) is a smaller bar that goes from tower to tower The purpose of the RSTB is to stiffen the body in cornering so the back of the car will track better. A lot of people have also reported that it eliminates creeking in the trunk lid. FRONT STRUT BRACE Made by OMP, Sparco, and Freedom Design. they are all adjustable bars that goe from front strut tower to strut tower. The affectiveness of these bars is widely debateable, but every little bit helps. The OMP and Sparco are steel tubalar designs, while the Freedom Design is a flat aluminum piece SUBFRAME CONNECTORS the only ones that I know of as of now are from the group buys on CEG. they weld/bolt (welding preferred) to the bottom of the car. it adds stiffness from the front to the back of the car, helping to transfer weight to the corners of the car while cornering. This often results in lifting a wheel off of the ground. While this makes the car a fun ride, it does make it a considerably rougher ride BOXED/TUBULAR CONTROL ARMS -boxed/tubular control arms add some stiffness to the rear suspension. I havent noticed a huge difference on either of my cars with the boxed arms. But it makes them stronger and will hold up better TUBULAR TOE ARMS - Stock toe arms are prone to bending. (esp when the shop jacks the car up by them) The double adjustable arms make setting the toe much easier and allows for a wider range of adjustment.
#27 (permalink) |
Did the part numbers change on the upper strut mounts and spring seats from 99-00 to 01-01?
01 Dark Shadow Grey Ford Cougar w/ Flowmaster, taillight covers, smoked sides, For Sale: Z3 Fenders, Full Body Kit, 18" Gunmetal Motegi MR3s http://www.cardomain.com/ride/578111 |
#28 (permalink) | |
99-00 Upper Mount 99-00 Rear spring seat Rear Suspention Layout
See My Cougar Here and Car DomainHow low is too low.... bump.. scrape... sparks.... sh$t!! Last edited by papatedroach; 06-11-2008 at 03:12 PM. |
#29 (permalink) |
Another additon to this, you do in fact need a chamber caster kit to properly align a cougar with BG's. I have the aligment sheet and will post it soon, the factory adjustments for chamber and caster are unable to compensate for the drop. Mine are adjusted as far as they can possibly go and still dont meet spec. You get dam close but will never have an in spec alignment. They get close enough to not cause any real problems, but you will have a very slight vibration at highway speeds.
See My Cougar Here and Car DomainHow low is too low.... bump.. scrape... sparks.... sh$t!! |
#30 (permalink) | |
3L Roush 'S'
CougarFest 2009 - Canada EH!!! 3L 99 Rio Red MTX , 91 306 Dech Coupe, 90 302 Twin Turbo Fox Rod, 88 LX Coupe, 96 Contour, Official Member of Ontario NECO, and MC-NECO PROUD MEMBER OF THE ND4SPD ARMY RED GLOVES RULE! See Ya Up Front! Greg Moore: 1975 - 1999 If you wanna Play, you gotta Pay! RIP Maverick
