#12 (permalink) |
Re: Suspension FAQ (Read This First)
ok
Rears: stock 17 svt 18 roush 19 bat 21 "aussie" 24 hollow Fronts: stock ? svt ?-1mm
#13 (permalink) | |
Correct > Quick
#14 (permalink) | |
Hook 'Em Horns
My 01 Zetec has a 20mm front bar.
Why buy new when you can restore? ![]() 01 Zetec MTX-Sold | 98 Tour SE Zetec ATX-sold | 06 Speed 6 GT | 78 Mustang Quote:
#15 (permalink) |
Secretary of the Inferior
Weight difference between the Zetec and Duratec are negligible at best. The Duratec is all aluminum, while the Zetec has a cast-iron block.
#17 (permalink) |
The Roush rear sway bar appears to be 21mm b/c the BAT 21mm bushings barely fit around it.
According to BAT, the diameters are as follows: FRONTS Contour = 20mm Cougar = 20mm SVT Contour = 19mm REARS Contour = 16mm Contour SE = 18mm Cougar = 18mm SVT = 19mm BAT/Roush = 21mm Aussie = 24mm (hollow)
#18 (permalink) |
Is back at ASU. Yeah.
How do we know what size our front sway bar is? (aside from actually measuring the thing- any year-to-year differences?)
#19 (permalink) | |
with the exception of the SVT tours which were 1mm smaller. just my 2 cents but the more you stiffen the springs, the less important the bulk of your sway bars will play on the handling [other than front to rear bias]. case in point, I have monsterously stiff springs, with every its bigger/better suspension upgrade. apparently at some point I snapped a sway bar endlinkt... I can confidently say the sway bar has zero effect on handling on my car [I've done this on stock too, ummm ya, it very much effects your handling]
#20 (permalink) |
According to Advance Auto Parts (i.e. Parts America):
Cougar front sway bar diameter = 20mm Cougar rear sway bar diameter = 18mm So the specs for the Cougar match those for the Contour SE but not the Contour SVT. Energy Suspension Bushings: Front: 45175G Rear: 45175G
