Results 1 to 7 of 7
Thread: 01-02 ground contols on a 99
    NECO Member AndrewM6097's Avatar
    Feb 2006
    Worcester Ma
    1,586
    Ok i tried to research this and got confused. Some people say you can do it without replacing anything, and some people say you can with certain parts. I also read you cant do it at all. What exactly do i need to make this work?? Or can it be done at all?
    Edit- sorry i meant to put this in the suspension section
    1999 MTX, 3.0, silver frost SVT UIM,LIM,CAMS,TB,INJECTORS,ECU,CLUTCH. AEM-GMK. MSDS-MAGNAFLOW. FIDANZA. KSPORT-JAGED RSTB. ADR. ALPINE. 215HP, 191TQ
    AIRCOUGAR PERFORMANCE
  2. #2
    I'm a nub...hehehe Lifetime Platinum MemberSuper Moderator LostRacer's Avatar
    Apr 2002
    Northern California
    14,337
    Re: 01-02 ground contols on a 99
    The One&Only!
    C.A.R.B # FU50
    XBL=LostRacer2
    PSN=LostRacer
    I hate to see you leave but I love to watch you walk away." So true...
  3. #3
    Feb 2006
    Worcester Ma
    1,586
    ground control/eibach makes the coilovers year specific. But ive read there is a certain part or parts i need to make it work.
  4. #4
    Apr 2002
    Northern California
    14,337
    Andy mentions the part needed. You need the rear springhats from a 99/00.
    The One&Only!
    C.A.R.B # FU50
    XBL=LostRacer2
    PSN=LostRacer
  5. #5
    Super Moderator Lifetime Platinum MemberSuper Moderator wadespencer99's Avatar
    Oct 2003
    Wellsboro, Pa
    12,446
    Which since you already have a 99 or 00....that isn't a problem.
    1999 Cougar 2.5 MTX - Being stripped and sold
    2002 Cougar C2 2.5 MTX - Being reborn and modded
    2004 F150 FX4 Supercab - Daily beater
  6. #6
    Feb 2006
    Worcester Ma
    1,586
    I apologize, im a bit tired so i just use all my mounts bearings and spring hats and im good to go. Thanks guys
  7. #7
    Oct 2003
    Wellsboro, Pa
    12,446
    I just put Konis and GCs on mine, so I just went through this.
    You will use the rear top seats...the ones that bolt to the car.
    In the front, you will NOT use the strut bearing, but rather the McMaster Carr bearings and washers listed in the Suspension FAQ.
  1. ? about Ground dynamics.com
    By Daywalker7VII in forum Exterior Cosmetics
    Last Post: 10-23-2004, 02:22 PM
  2. Ground ?
    By PeDL2DaMeDL in forum Audio & Electrical
    Last Post: 05-08-2004, 05:10 PM
  3. Which is ground?
    By LMagenis in forum Audio & Electrical
    Last Post: 07-09-2002, 09:51 AM
  4. Good Ground
    By AuburnCougar in forum Audio & Electrical
    Last Post: 04-11-2002, 05:22 PM
  5. what's ground control??
    By Gary in forum General Info
    Last Post: 09-14-2001, 12:21 AM
SEO by vBSEO 3.5.0 RC2 ©2010, Crawlability, Inc.
