Old 07-11-2008, 06:46 PM   #1 (permalink)
Axle question
While changing out the struts, I pulled the axle out. Everything went back together fine, but now I have a thud noise at speed like something is hitting every rotation..do the axles have to go back in a certain way..or does it matter?
rallymedik is offline
Old 07-14-2008, 03:55 PM   #2 (permalink)
RobbieD's Avatar
Re: Axle question
There are three bearing inside the boot. I once pulled an axle out too far and when I pushed it back together a bearing came off. It only had two, which made it asymmetrical, and caused a vibration you could call a thump. To fix it I cut the metal band holding the boot on. I looked inside and sure enough a bearing was floating in the grease. I pushed it back on and used a plastic zip tie to put the boot back on. It still holds fine after two summers and winters. Those zip ties are f*cking amazing. They hold most of my car together.
99 MTX - Eibach, KYB, Energy Suspension, SVT Goodies
Weight Reductions - Put your cat on a diet!
RobbieD is offline
