Old 06-22-2008, 10:19 AM   #1 (permalink)
CTC
CTC's Avatar
custom adjustable cambers
do you know someone that try to mod the suspension for put this?:
K-sport
CTC is offline
Old 06-22-2008, 10:58 AM   #2 (permalink)
Re: custom adjustable cambers
wont work without cutting out and welding in a new strut tower plate at the very least.
Daniel,
'97 Contour GL"T"
2000 Black SVTC #391
Turbo Zetec 'tour is offline
Old 06-22-2008, 11:53 PM   #3 (permalink)
when i saw that, i got excited and thought about buying the KSport coilovers. but then i learned that the coilovers do not include the "pillow top." KSport claims that they are a universal fit. to install them you would have to cut out the top of your strut tower. if the pillow top could be mounted to the strut tower, it could be made to work.
Old 07-01-2008, 06:18 PM   #4 (permalink)
CTC
CTC's Avatar
someone will try it? :-P
CTC is offline
Old 07-02-2008, 11:02 AM   #5 (permalink)
Someone did do it on the Cougar race car. I can't remember who the owner was though.
Old 07-02-2008, 12:13 PM   #6 (permalink)
I hear voices...
sonza68's Avatar
Images: 14
Leo Capaldi and the Mumm Brothers both did that to their race cars.
sonza68 is offline
Old 07-07-2008, 11:04 AM   #7 (permalink)
I own the Mumm Bros. car now and have all the designs for the strut tops at the front and rear. The diagrams relate to a stamped steel top, pillow block strut adjuster, but they went to a machined billet aluminum version in the second or third version to improve strength and reduce weight. As well, the fabricated lower control arms are adjustable for track as well. This could be used to adjust camber and caster at the bottom without touching the upper mount.
I will see if I have an electronic copy of the diagram somewhere.
Eric Nummelin
2003 Jaguar XJR with Brembo option
1991 RX7 Super Touring Car CCTCC #23
1976 F250 Extenda Cab with balanced/blueprinted 460
2002 Cougar Speed WC Car CCTCC # 75
23racer is offline
Old 07-07-2008, 11:46 AM   #8 (permalink)
I found some pictures. The first is the steel fabbed original camber plate. It does require you to cut out the top of your strut.
The second shot is how the strut top looks today. The important thing to remember is that this car uses Dynamic coilovers so the upper strut mount will be different than a car that uses stock style springs.
Eric Nummelin
23racer is offline
Old 07-07-2008, 11:55 AM   #9 (permalink)
I hear voices...
sonza68's Avatar
Images: 14
Very interesting. I'd never seen a close up of those before. What does the upper portion of the Dynamic coilovers look like? I've heard of them, but know almost nothing about them.
sonza68 is offline
Old 07-07-2008, 12:24 PM   #10 (permalink)
Thought it might be helpful to have a shot of the fabbed control arm as well.
23racer is offline
