Old 06-21-2008, 11:52 PM   #1 (permalink)
bushings
so this maybe a few noobie question but how do you inspect your bushings to see if their bad? i kept hearing a crisp poping noise when i go over uneven roads. usually only when one side or a single suspension area is put under stress
Thanks in advance
Dr3w2k5 is offline
Old 06-30-2008, 11:21 PM   #2 (permalink)
Got Rice?!???!!??
Drewmanfu0's Avatar
Images: 49
Re: bushings
Might checy your swaybar links. The rear swaybar bushings do like to go and the only way I was able to find them being bad was to have someone stand in the door sill and bounce the car while feeling the bar.
But the front links are dirt crap and should have been replaced with Moog immediately once the car rolled off the showroom floor.
Drewmanfu0 is offline
