Old 08-11-2008, 08:28 AM   #71 (permalink)
shoot me now
Re: D2 Coilover Damper Kit
when i run the 16's with the V710's i have very little clearance on the back and i mean barely. but with the 18's i dont have any problems. I need to raise mine up higher cause i have some rubbing issues on the back (on the outside) but thats with a trunk load of stuff and the car weighed down and hitting bumps
didnt have any issues with the knuckles though
BUY COUGARFEST RAFFLE TICKETS
jaged is offline
Old 08-11-2008, 11:05 AM   #72 (permalink)
Topik's Avatar
It might have just not had enough machined off the front perches. As for the rear, they are barely not touching. I will be going with longer studs in the rear and spacers. Otherwise the coilovers were cake to install. No spring compressors are needed. Also the fronts come with a 1/4 spacer on top of the coilover that is not needed.
Barack the c*nt hunter
402whp
379 ft lb.
1999 3l turbo cougar
1998.5 Sh*tVT contour #3162
Topik is offline
Old 08-11-2008, 11:47 AM   #73 (permalink)
shoot me now
where do you have them adjusted to height wise? i think i have 1.5" left and im going to turn them up some more
jaged is offline
Old 08-11-2008, 01:27 PM   #74 (permalink)
Topik's Avatar
tuckin tire in the front and rears still have an inch of wheel gap. Still dialing everything in to be honest. Downpipe is almost kissing the ground.
402whp
379 ft lb.
Topik is offline
Old 08-11-2008, 04:10 PM   #75 (permalink)
ya the farthers I was compfortable raising the front was a little over a finger of gap.
I never had a problem with the rears because my rears are still sitting ABOVE stock ride height [I guess if I ever wanted to do anything competitive with the car, I'd lose the 4" rake I have going... but until then, it simply looks too badass... plus when dropped I simply cant get a jack under it with the subframe connectors].
but topik, keep us updated on the spacers/studs. I NEED SOME. forgot about that, but my wheel clearance is just a tad too close to be compfortable [but no rubbing]. also be careful that the brake lines are secured that they dont get caught between the strut and the wheel. I had that happen once.
Old 08-12-2008, 01:02 AM   #76 (permalink)
Topik's Avatar
I will. I still have alot of dialing in to do still and will update. Especially will be fun figuring out if my slicks will work. haha
402whp
379 ft lb.
Topik is offline
Old 08-12-2008, 01:07 AM   #77 (permalink)
shoot me now
it is a lot of trial. i raised the rears up an inch tonight. drove around the neighborhood, which is rough with the slicks in the trunk. no rubbing in the rear. have a couple weeks till the next event though, so who knows what will happen with the slicks on course
jaged is offline
Old 08-30-2008, 06:49 PM   #78 (permalink)
Topik's Avatar
Before d2's with visteon kit:
After with d2's and without visteon kit
Mind you I had koni yellows and eibachs on in the first pic and in the second pic its not full slammed and the springs still havent settled.
Topik is offline
Old 08-31-2008, 01:58 AM   #79 (permalink)
I hear voices...
sonza68's Avatar
Images: 14
The second pic is barely lowered from max height in the front.
sonza68 is offline
Old 08-31-2008, 02:24 AM   #80 (permalink)
Claymore
LostRacer's Avatar
saving up now for a set.
The One&Only!
C.A.R.B # FU50
LostRacer is online now
