Old 07-18-2008, 05:03 PM   #61 (permalink)
Topik's Avatar
Re: D2 Coilover Damper Kit
Ok FYI the d2-f19's appear to come with 5.2 front and 5.1 rear spring rates from erzperformance.com where you can get these 880 shipped. The gentlemen I spoke with says its very easy to have stiffer or softer springs made however you must provide the model number as the f19s are updated compared to the original d2's which are f16's IIRC. Correct me if im wrong XRtony.
p.s. I will be trying out these spring rates to see how they ride for info purposes and I will be switching to a stiffer rate for the cars new setup.
Barack the c*nt hunter
402whp
379 ft lb.
1999 3l turbo cougar
1998.5 Sh*tVT contour #3162
Topik is offline
Old 07-23-2008, 08:17 PM   #62 (permalink)
Looky looky...
I'll be putting them in within the next few days hopefully. Don't worry I'll take plenty of pictures.
CSVT#49 is offline
Old 07-23-2008, 08:19 PM   #63 (permalink)
Claymore
LostRacer's Avatar
me likes
The One&Only!
C.A.R.B # FU50
LostRacer is offline
Old 07-28-2008, 04:19 PM   #64 (permalink)
shoot me now
i all ready see one difference, the adjustment knobs are shorter than the d2s
BUY COUGARFEST RAFFLE TICKETS
jaged is offline
Old 07-28-2008, 05:39 PM   #65 (permalink)
wayyyy shorter
Old 08-10-2008, 08:59 PM   #66 (permalink)
Topik's Avatar
So the d2's are on the car now. Ran into a few issues im not sure you others have run into. First thing I ran into was the rear tires touching the bottom perch lock nut. I am running rota slip streams and wide tires so its possible thats why. Secondly the front coilovers wouldnt even fit into the knuckles without spreading the knuckle pinch area severely. A few other little glitches. Pictures will be added when the car is done(rear wheel spacers, new endlinks, etc etc.)
402whp
379 ft lb.
Topik is offline
Old 08-10-2008, 09:17 PM   #67 (permalink)
Skywalker's Avatar
Can anyone else confirm if they ran into these issues?
2000 BLACK MTX ROUSH #2749
http://www.flickr.com/photos/30297113@N06/sets/
Skywalker is offline
Old 08-10-2008, 09:42 PM   #68 (permalink)
Look, it's Randy!
BigBalledOX's Avatar
Images: 53
I can confirm I did NOT . . . don't think Terry or Sonza or jaged did either.
its a money pit!
Just a lost soul swimming in a fish bowl, year after year.
BigBalledOX is offline
Old 08-11-2008, 07:38 AM   #69 (permalink)
I hear voices...
sonza68's Avatar
Images: 14
I didn't. The front struts took bit of persuading, but I didn't need to do significant spreading to get them in the knuckle. I have minimal clearance on the rear tire, but it is a positive clearance (225/50/16 Ecsta V710s on stock wheels and 225/45/17 Ecsta MXs on 17x7.5 Kosei K1 Racings).
sonza68 is offline
Old 08-11-2008, 08:22 AM   #70 (permalink)
Skywalker's Avatar
topik what size rims and tires do you have?
