Old 06-08-2008, 03:02 PM   #1 (permalink)
3L Roush 'S'
Platinum MemberModerator
MaverickFlyer's Avatar
Images: 6
SVT Front Sway bar Vs. Stock
So SVT actually reduced the size of the SVT's front sway bar to improve the front suspensions grip and reduce under steer. I've heard people say the opposite is true and they swap out the SVT bar and put the larger stock one back in. I have both bars and want to know which one I should use. Does anyone know which one is better and why?
MaverickFlyer is offline
Old 06-08-2008, 03:42 PM   #2 (permalink)
deliveryguy's Avatar
Re: SVT Front Sway bar Vs. Stock
I would assume a smaller bar would increase the overall torsion of the suspension. I haven't experimented or anything; this is just based off reading. Did you notice a more "universal" bumpy ride with the SVT? Say you hit a bump on the right side while you were cornering left; did you ever feel like both your right and left hit the bump? I would think the SVT decreases understeer on fast cornering because of the increased torsion and therefore more even distribution and less roll, but I'm not positive.
WTB
•99-00 Fog Lamps •Aussie Corner Reflectors (01-02) •99-00 Wheel Cap
deliveryguy is offline
Old 06-08-2008, 04:30 PM   #3 (permalink)
Secretary of the Inferior
B3NN3TT's Avatar
Images: 52
A smaller front bar causes the front end to bite harder, so it's much easier to get tail-happy in hard cornering.
Stock balance is set for understeer at the limit, as a "safety" feature (stage 1). The larger rear bar neutralizes it a bit more (stage 2). Adding a smaller front bar on TOP of a larger rear bar gets more oversteer (stage 3).
I guess the larger rear bar and smaller front bar are designed to make the car handle as much like a RWD car as a FWD car can.
Andy- Ohio NECO's "Green Guy"
you make my head hurt.
B3NN3TT is offline
Old 06-09-2008, 09:02 AM   #4 (permalink)
A smaller front bar causes the the rear end to rotate better.
I guess the larger rear bar and smaller front bar are designed to make the car handle as neutral as possible.
Fixed
the SVT front bar with a 21mm rear bar should be pretty well balanced.
Daniel,
'97 Contour GL"T"
2000 Black SVTC #391
Turbo Zetec 'tour is online now
Old 06-09-2008, 02:21 PM   #5 (permalink)
B3NN3TT's Avatar
Images: 52
A stock front bar with a 21mm rear is pretty well-balanced. My rear will rotate handily with the Roush bar in place (if I force it), and I haven't touched the front bar at all.
B3NN3TT is offline
Old 06-09-2008, 04:15 PM   #6 (permalink)
cawong11's Avatar
I never liked how my SVT rolled over the tires with its stock 20mm front bar/19mm rear bar. I always liked how the stock 1995 Contour SE's cornered with 20mm in the front, 19mm in the rear. The car was very neutral and sat flat in corners, with stock SE suspension (stiffer than all other stock Contour/Cougar suspensions).
I went with the same bar sizes on my SVT, 20mm front, 19mm rear, and it cornered just the way I like it, neutral to oversteer (my taste). Once I installed the BAT suspension, handling improved. I didn't have a need to go to a 21mm rear bar, because I was able to adjust the tire pressures to get the cornering just right.
Christopher A. Wong
CTA MOTORSPORTS
chris@ctamotorsports.com
cawong11 is offline
Old 06-09-2008, 05:03 PM   #7 (permalink)
Jorgen's Avatar
I don't have a side by side comparison with my Stock front and SVT front bars in but I like how my car rides now (SVT front stock rear) and assume it will only get a little nicer once I drop my rear bar (aussie) in toward the end of the month.
1969 Triumph Spitfire MK3
1996 Audi A4 V6 5-Speed
1999 DT Green V6 MTX Built 8/7/98. She's got a few mods.
2004 Explorer XLT, V6, Auto, 4x4
Jorgen is offline
Old 06-09-2008, 05:18 PM   #8 (permalink)
3L Roush 'S'
Images: 6
Now I'm even more confused???
I have the 21mm Bat rear bar installed. (I also have a Roush bar in the Garage) I just can't decide what to put in the Front. I want it to be as neutral as possible but a bit more oversteer wouldn't be bad as I'm used to driving the Mustang. I can't stand the understeer my car has right now. That's why I'm leaning towards the SVT front bar to get a bit more bite.
What should I do?
Old 06-09-2008, 05:32 PM   #9 (permalink)
I hear voices...
sonza68's Avatar
Images: 14
I'd go with the SVT front bar. Not sure about the rear though as I'm only familiar with stock and Aussie.
sonza68 is offline
Old 06-09-2008, 05:43 PM   #10 (permalink)
B3NN3TT's Avatar
Images: 52
Definitely do to the SVT front bar if you don't like the understeer you have now.
The individual sizes of the bars are not the whole story; it's really all about the RELATIONSHIP in sizes between the two that make the difference.
B3NN3TT is offline
