Closed Thread
Old 03-19-2008, 06:06 PM   #1 (permalink)
Git some!
Platinum MemberAdministrator
JScullin's Avatar
Question The Nuts & Bolts Guide to: Suspension
Front Suspension:
• Strut pinch bolt - 18mm
• Brake line bracket - 15mm
• Sway bar endlink - 15mm plus a 17mm wrench (factory only). Revised links have 14mm wrench on stud
• Strut tower nut (in the engine bay, holds the strut into the tower) - 18mm
• Ball joint pinch bolt - T55(will verify) and 18mm. Some have 15mm bolt and 18mm nut
• LCA bolts (4-bolt arms)- 15mm, 17mm, and 18mm
• Front subframe bolts - 21mm
• Lug nuts - 19mm OR 21mm depending on style
• Front brackets for radiator support to subframe - 8mm
• A/C drier to subframe - 10mm
• Steering rack to subframe - 18mm (IIRC)
• P.S. rack cover plate - 13mm
• Front sway bar brackets - 13mm
• Splash sheilds Pass. side - 10mm
• Axle nuts 32mm OR 1 1/4" (both fit perfect)
• Steering column to P.S.rack pinch bolt - 10mm
• Tie rod ends - 15 mm nuts
Rear suspension:
• Strut tower bolts - 10mm
• Toe control arm bolt (at the knuckle) - 15mm
• Sway bar endlink (at the sway bar) - 15mm and 13mm
• Sway bar endlink (at the control arm) -15mm
• Lower control arm (at the knuckle) - 15mm and 18mm
• Subframe - 15mm
• Sway bar - 13mm
This guide will be updated as needed. Thanks to those who contributed.
"You know what the chain of command is? It's the chain I go and beat you with until you realize who's in goram command here." - Jayne Cobb
JScullin is offline
Closed Thread
