Quick Question...(Well maybe not so quick)
Results 1 to 6 of 6
Thread: Quick Question...(Well maybe not so quick)
    Dopeshiet7
    Guest
    I want to put an electronic ignition on my 1999 V6 cougar but....
    since the cougar's ignition system is distributorless i dont know what the hell to get.
    does anyone have any suggestions?
    2000 Oct
    972
    www.spmotorsports.com they have a msd ignition system for each engine the cougar has. Check them out.
    The Linux philosophy is 'Laugh in the face of danger'. Oops. Wrong One. 'Do it yourself'. Yes, that's it.
    - Linus Torvalds
    There are two major products that came out of Berkeley: LSD and UNIX. We don't believe this to be a coincidence.
    - Jeremy S. Anderson
    2000 Oct
    1,417
    Yeah, MSD is the way to go.....stay away from Jacobs.......
    Nikolas
    Fastest Cougar In The West
    WillowSprings 2.5 Mile Road Course: 1:44.7
    E-Mail:
    Nikolas@Draxas
    Draxas.com
    mprtklr
    Guest
    MSD is the way to go, but i have a MSD DIS-4 and race wires and bosch +4 plugs and it has not helped me but a tiny bit
    2000 Oct
    1,417
    yeah, i dont think you should expect to see any gains from running an MSD unit on our NA engines....Im not gonna upgrade to a Vortech though without also doing the MSD box. In a forced induction situation, i would think the stonger spark and better plugs and wire would help more, making sure they were properly gapped of course.
    Nikolas
    E-Mail:
    Nikolas@Draxas
    Draxas.com
    mprtklr
    Guest
    thats true, the only problem is that i have experienced problems with ignition systems with a forced induction creating more than 8 psi of boost. the ignition is too early causing massive misfires. this apparently is common in the duratec engine. i would recommend going a step up on the ignition to maybe a MSD race kit, because you will need to retard the ignition somewhat. This is the info i got from Jackson racing, never seen a cougar with a vortech yet, only a paxton and jackson racing supercharger, but i would assume vortechs are the same way
  1. quick question
    By marinofan in forum Ohio NECO
    Last Post: 2008-06-30, 10:51 AM
  2. Quick question?
    By adam in forum How To's
    Last Post: 2007-03-31, 07:04 PM
  3. Quick Question?
    By adam in forum AZ NECO
    Last Post: 2007-03-29, 08:51 PM
  4. Quick Question
    By CougarGurl in forum Transmission Performance
    Last Post: 2004-08-31, 12:20 PM
  5. quick O2 question could use a quick answer
    By eurocrisp in forum Problems
    Last Post: 2004-05-11, 01:04 AM
