my cable snapped, and my actual ebrake has to much play it wiggles back n forth, so i need a cable and the assemble if anyone has in the area msg me with pricces.
Thanks
Thanks
drums or discs in the rear, the year of the vehicle also makes a difference.
so u want both RH and LH rear cables as well as the equalizer? (equalizer includes e-brake handle)
'02 DSG
SVT UIM, LIM, TB, PCM with Sniper tune, 19LB injectors, NPG CAI, gutted precats, test pipe, 2.5" exhaust, B&M
ST200 RSTB, OMP FSTB, KYB GR2, B&G
it is a 99 and disk all around.
and the cable snapped right after the connection to the e brake handle.
so im not too sure what i need
Still need that stuff some on plz help me oout!!!
Did it break before or after the bracket? Theres a main cable going to your ebrake handle then a metal bracket that your LH and RH cables go into.
MICH,
99 Laser Red 3L Roush Cougar & 08 Ford Edge SEL
its the front ebrake cable. the one connected to the actual handle.
