Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 20
Thread: My 3L swap
  1. #11
    NECO Member michcougar's Avatar
    Jan 2004
    Fort Erie, ontario
    2,874
    Re: My 3L swap
    Today is going to be a big day.
    Suspension is going back in. Injector harness is being moded and installed in the car. Roll resistors going back in. Going to flush the coolant lines, put the new coolant in. Fill the trans with fluid and fire her up
    Tomorow im going to fix all the vacuum leaks but I figure today I should be able to start it atleast.
    MICH,
    99 Laser red 3L Roush Cougar
  2. #12
    NECO Member boarder4life's Avatar
    Mar 2007
    Vaughan, on
    2,868
    Re: My 3L swap
    Mich, if you ran the vacuum lines correctly i doubt you will have any leaks.
  3. #13
    3L Roush 'S' Platinum MemberModerator MaverickFlyer's Avatar
    Aug 2004
    Aurora, Ontario
    20,406
    Re: My 3L swap
    Don't Forget Motor Oil!
    Oh and Power steering fluid. Also check the brake fluid since we bled the clutch.
    3L 99 Rio Red MTX , Nummelin Motorsport Group
    91 306 Dech Coupe, 08 Escape, 96 Contour, 01 Yamaha R6
    Official Member of Ontario NECO, and MC-NECO
    PROUD MEMBER OF THE ND4SPD ARMY
    www.roadawareness.ca
  4. #14
    Jan 2004
    Fort Erie, ontario
    2,874
    Re: My 3L swap
    Thats the problem, I dont know what lines to keep.
    MICH,
  5. #15
    Mar 2007
    Vaughan, on
    2,868
    Re: My 3L swap
    The only vacuum line you wont be keeping is the green one for the EGR.
    grey goes to hvac
    red goes to fuel
    then run the big black one from the back of the uim goes to the brake booster.
    The car probably won't run if all the vacuum line are not closed off. The fuel is regulated by the vacuum going to the regulator. So the less vacuum there is going to it, the more fuel it allows through.
  6. #16
    Jan 2004
    Fort Erie, ontario
    2,874
    Re: My 3L swap
    Update on today: Didnt get as much done as I planned but I am making progress. I finished the injector harness and it turned out PERFECT. Problem was it wasnt clearing the UIM so I had to cut some plastic out between the front and back divider between the UIM. You cant see any of it but it gave me just enought room for the fuel rail and the injector harness to fit in perfectly.
    Tomorow im going to flush the cooling system. Throw all my fluids in and throw my lowering springs back on and mount it up on the car.
    MICH,
  7. #17
    Jan 2004
    Fort Erie, ontario
    2,874
    Re: My 3L swap
    Update: Still not started. Progress is slow but steady. Who ever said this would take 1 day lol
    So the vacuum lines are done. Roll resistors are back in in the car. All wires are connected except this random one. Any help? Do I need it ? it looks like a ground for something?
    I put the oil and trans fluid in and flushed the coolant. Its cool how much coolant stays in your system. Tomorow I need to figure out a better place for my coil pack as the spark plug wires do not reach.
    MICH,
  8. #18
    Mar 2007
    Vaughan, on
    2,868
    Re: My 3L swap
    Mich,
    that is your knock sensor, I can't believe i forgot to hook that up when i was down there. Sorry about that.
    Good work on the vacuum lines and fuel system.
    Remember when you are starting it a few tips.
    before you go turning it over reprime your fuel system. Just turn the key to on position without cranking enough times till you hear the system is re primed(the pump will run a couple seconds each time you do it and you can hear the change in pitch when its good)
    and to get oil through the motor, unplug your coil pack after you have charged your fuel system and crank it for a few seconds 3 or 4 times. It will move oil through your motor so its not so harsh on first start.
    replug it and leave the cap off the coolant tank to get any air out of the system. then start her up!
  9. #19
    Jan 2004
    Fort Erie, ontario
    2,874
    Re: My 3L swap
    UPDATE:
    1000 km so far and all is good! Still havent fixed my vacuum lines as I have been busy with other side jobs. As long as it runs and idles im in not rush to fix the small stuff.
    Averaging 29MPG so far, keeping it under 3k RPM. Starting the datalogs to tweak the tune this week
    MICH,
  10. #20
    Aug 2004
    Aurora, Ontario
    20,406
    Re: My 3L swap
    Glad to hear it's treating you well. I drove the my Cougar last night for the fist time in 7 months. I missed her! It's nice to have a working sunroof after all these years!
  1. ecu swap w/ manual swap
    By evilkowz in forum Transmission Performance
    Last Post: 10-01-2005, 01:42 AM
  2. 3.0 upper swap vs 3.0 swap?
    By HOYA in forum Land Of Lincoln NECO
    Last Post: 05-26-2003, 06:27 PM
  3. Is the 99-00 to 01-02 headlight swap a straight swap?
    By silver99kat in forum Exterior Cosmetics
    Last Post: 04-22-2003, 12:15 AM
  4. V8 Swap
    By RodneyBur in forum 3.0L DURATEC Performance
    Last Post: 01-01-2003, 01:40 PM
  5. is the 3 liter swap or the sVT swap.......
    By Instigator in forum 2.5L DURATEC Performance
    Last Post: 06-13-2002, 10:06 AM
SEO by vBSEO
