Go Back   NECO Forums > Chapters > NECO NorthWest
Old 01-24-2008, 09:00 PM   #1 (permalink)
In Need of HELP!!
Ok so it think my car is falling apart. Its a 99 atx V6, i was wondering if anyone knew where to go to get parts for a half decent price. I am in Portland Oregon. I need stuff like tune up parts shocks struts brakes, and i am having a crazy time with my tranny it is slamming into first and second but only when i have half a tank or less of gas. and my wheel area pops when i try to turn into a parking spot does anyone know what this could be? Thanks guys and girls
Loyalty4242 is offline
Old 01-25-2008, 01:07 AM   #2 (permalink)
CougarTech's Avatar
Re: In Need of HELP!!
Buy a new car.. Lol. Not sure where to get parts, but it sounds like you need to replace all of your bushings in your suspension along with your tie-rod and and ball-joint. You'll probably need to service your ATX, or just swap in a new/used one. Brakes are easy. Visit your local AutoZone or w/e is close by. Shocks and struts.. are you sure you need them? What's wrong with yours?
2000 Cougar 2.5L V6 MTX
Mods: MSDS headers and Y-Pipe (High temp Ceramic coated), Trubendz test pipe w/ high flow cat, 2.5" SS Trubendz Dual exit exhaust w/ Borla muffler
CougarTech is offline
Old 01-25-2008, 01:18 AM   #3 (permalink)
well that helps a little bit i did a plug and wire change out not too long ago and breaks wont be too hard but if i get 17 inch rims should i just do a coil over suspension and would it be easier to do joints and what not or just a whole new driver side and passenger side axel?? the back end of my car squeeks like crazy when i go over the smallest bump and it sound horrible
Old 01-25-2008, 01:19 AM   #4 (permalink)
Calendar Lady
Goldie's Avatar
Images: 174
I'd agree... brakes are easy enough to do on your own and will save a ton over having a shop do them (lots of places on line to get a good deal on pads/rotors). Struts & bushings I'd have Les Schwab take a look at it.
For the trans, automatic or manual? No matter which, I don't think it would have anything to do with the amount of fuel you have.
Goldie is offline
Old 01-25-2008, 01:23 AM   #5 (permalink)
Its an atx i have 146700 miles i bought it with 123000 on it ill go to les schwab this weekend a Goldie do you know any good sites with brakes and rotors possibly for a decent price Thanks a bunch
Old 01-25-2008, 01:23 AM   #6 (permalink)
CougarTech's Avatar
Ok. If you are going to do coil overs, you will need the coil over kit, the struts, new bushings for your sway bar, control arms, sway bar links for the front, and for the rear you will need bushings for your lateral arms mounted near the back centre of your car. You will probably also want to change your ball-joint (don't forget to grease it), and that should be good for your suspension. You should also get a camber/caster kit, and get a wheel alignment at the same time, especially since you are doing a lot of suspension work. I don't understand what you mean by a new axle? Your axel has nothing to do with your suspension. It is simply a rod with a bellows boot on it with a spindle that goes into your steering knuckle (hub). If this doesn't make any sense to you, let me know and I can go into more detail for anything you request.
Old 01-25-2008, 01:28 AM   #7 (permalink)
Yea i dont know why it only does the hard slamming shifts if i have less than half a tank? if i get the chance this weekend i will take it to my friends shop in vancouver and see if he can come up with an idea why it does that, Do you think if he orders the parts it willl be cheaper than me going out and ordering them im trying to get this stuff fixed so i can get my car rolling and start to mod it a little bit Goldie do you know of any places around Portland that are mod shops and where would a good place be to get my windows tinted Thanks
Old 01-25-2008, 01:30 AM   #8 (permalink)
CougarTech's Avatar
The gas tank level literally has NOTHING to do with your transmission slam shifting.. It's just a total coincidence (sp?). If your transmission is slamming into first and second there is a problem, most likely with your syncros in the first two gears. Those are hard to find/replace. It's better off to find a new/used ATX.
Old 01-25-2008, 01:31 AM   #9 (permalink)
Hey tech then would you know why my car would make a wierd popping noise when i try to turn in to a confined space such as parking at like the mall and wal mart it when i have a small turning radius it also does it when i back out of the parking spot it doesnt do it if i am turning off one street to another or while i am taking a corner or anything only while i try to turn to park
Old 01-25-2008, 01:31 AM   #10 (permalink)
CougarTech's Avatar
Better yet.. perfect opportunity to do an MTX swap!
