Re: Rear brakes scraping sound
Could be the sensors in the pad warning you that you need to change them. Pull the tire off and see how much life it left on the pad.
Nitrous is like a hot girl with a STD you want to hit it but are afraid of the concequences ![]() http://profile.myspace.com/index.cfm...endid=47214562 |
Obey
My rear drums have finally worn down at 97k miles. They're making a sort of faint grinding noise. Do you have rear drums?
Skolenimation: Graphic Design | Modifications @ CougarDB.com | NEW! Flickr Account ![]() "In the beginning of a change, the patriot is a scarce man, and brave, and hated and scorned. When his cause succeeds, the timid join him, for then it costs nothing to be a patriot." - Mark Twain |
Check your Rotors....might be cracked? IF your doing hard breaking that might of screwed with them, dont know if stock rotors can take a beating. You might get more help under "problems" section on the forum
Check to see if you caught a rock up in there. I had that happen to a F-150 I had once, right front disc brake. Sound was inconsistent, scraping noise. Rock (pebble, really) was between the caliper and rotor. Still don't see how it stayed there, but it did. Good luck.
2 Cougars (01 highly modified & 02 35th Ed.) + 2 Mustangs (01 GT Saleen/Steeda hybrid & 08 Shelby GT500) + 1 08 SuperDuty F-350 = 1 broke Soldier ![]()
