If someone around here has a stock (new or used) clutch and pressure plate lying around and a few minutes can you measure:
the thickness of the actual clutch disc
the distance from the pressure plate mounting surface to the friction surface
thanks
thanks
PuckPuck.Com
From the Ford CD-
Pressed clutch thickness in new condition 7.3 mm
Minimum pressed clutch thickness worn 5.8 mm
No notes on the pressure plate.
B3NN3TT • • CougarDB • • CarDomain • • Facebook • • deviantART • • Last.fm • • Twitter
I'll check the garage, I think I might still have my old stuff hanging around somewhere.
Current: 2005 Audi S4, 2004 Volvo S40 T5
Former: 2004 Ex XLT, 99 Cougar, 99 ZX2, 98 Ex Sport, 96 A4, 90 Sunbird Convert, 90 Jetta Diesel, 82 Rabbit Diesel, 69 Triumph Spitfire, 1989 325i Convertible
please do, I would really appreciate it
Thanks
PuckPuck.Com
I en't located mine yet. I think it might have been ditched when I bought my hosue and moved. not sure though. I will keep an eye out and let you know if I find it.
