#31 (permalink) |
Rolling Chassis
![]() Join Date: Nov 2002
Nice Pierre, the engine bay will look great all freshly painted! :D
And yeah, the spray on caliper paint is crap, good choice on the brush on stuff. I initially used the spray stuff on my stock calipers and after a year they looked like crap. Puck, what FSTB to you have? Wondering what would cause the upper strut mounts to bend like that, and hoping we can find a solution... E1
#32 (permalink) |
Rolling Chassis
Oh Puck, just in case ya haven't seen this yet, check out Warmonger's site on my server here:
http://www.rumodded.com/warmonger/ Lots of useful XLS docs, and good info there. Tho I'm sure you know most of it already, ya never know if you'll find a gem in there. ![]() E1
#34 (permalink) |
Rolling Chassis
Ah, ya sure its not the FSTB that caused the problems? I know on Brad's car his freedom design was ALL screwed up and bent to hell, when I asked wtf happened Brad said it did it to itself. Looking at the mounting for that bar the metal was rather weak compared to the OMP, which has a good solid plate for the mounting.
E1
#35 (permalink) | |
T3/T4 60-1
What I "think" it was: The downside of the camber/caster kits we have is that I can't have 0 caster, and any camber I desire. When you add negative or positive camber, you end up always removing negative or positive caster. And if you remove negative or positive camber, you end up always adding negative or positive caster. Basically I can't change one without changing the other. When getting the alignment set, I had a choice between dead on camber, or dead on caster. I chose camber, as caster has a much lower effect on overall driving dynamics, and little to no effect on tire wear. Next I got to chose, negative caster, or positive caster. Since positive caster gives a more stable ride in a front wheel drive car, as well as a slight increase in camber on the outside wheels when turning, thus slightly increasing tire contact patch, I chose that. The problem with positive caster, on a wheel that excercises larger amounts of torque, is the bad angles between how torque excercises the upwards angle forces, versus the angle of strut. Red is torque angle, blue is suspension angle. This may also be the reason why I had so little wheel hop. Using this setup, the wheel doesn't really want to hop, because the suspension will not allow it. The bad news is the result to the upper strut mounts. ![]() The above was my theory... based on how my car was setup, what I experienced in ride, and what the end result to the components were. I may or may not be correct. PS: Thanks for the link to warmonger's site. Bookmarked!
#36 (permalink) |
Rolling Chassis
Ah, that makes a lot of sense now... Man, there's gotta be something that can be done though, wouldn't you think?
E1
#37 (permalink) |
Wasn't someone selling much thicker plates for these adjustable camber kits? I am sure I saw that on CEG awhile back....they said the replacement plates were about twice as thick.
--george
2000 Rio Red 2.5L MTX - see mods in links CF2K6 - 3rd Interior, 3rd Exterior --- CF2K7 - 2nd Interior, 3rd Exterior Me on CougarDB - Me on TeamNECO - Me on MotorTopia
#39 (permalink) | |
Banned
#40 (permalink) | |
3L Roush 'S'
CougarFest 2009 - Canada EH!!! 3L 99 Rio Red MTX , 91 306 Dech Coupe, 90 302 Twin Turbo Fox Rod, 88 LX Coupe, 96 Contour, Official Member of Ontario NECO, and MC-NECO PROUD MEMBER OF THE ND4SPD ARMY RED GLOVES RULE! See Ya Up Front! Greg Moore: 1975 - 1999 If you wanna Play, you gotta Pay! RIP Maverick
