Cold as hell in minnesota!!!
Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
Thread: Cold as hell in minnesota!!!
    2011 Jan
    Faribault, Minnesota, United States, 104047646298921, Faribault, Minnesota
    8
    Lightbulb Cold as hell in minnesota!!!
    So I let someone borrow my 99 cougar and it was leaking anit freeze and they still drove it. What ended up happing is they over heated it and now it will not start... idk what I should do. Should I just get the head changed or should I through a different motor into it?
    2002 Jun
    Columbus, Ohio
    19,875
    Re: Cold as hell in minnesota!!!
    Make sure you know what the problem is before you throw in the towel. Sounds like a blown head gasket or cracked head, but you never can tell. A compression test would tell for sure.
    If it IS a cylinder head, it's probably simpler to replace the engine entirely, and probably not much more expensive. R&R a cylinder head on the twin-cam engine like this one is a nasty job, and people often pull the engine entirely in order to get the space to do it.
    NECO Member Ksadowy's Avatar
    2010 Aug
    Winnipeg, Manitoba, Canada
    900
    So i clicked into this thread, wondering just how cold is "cold as hell in Minnesota"....and found nothing relating to temperatures, unless you count the over heating engine.
    Anyways, I agree with Bennett: Figure out the problem, figure out the possible cures, then make a decision.
    1999 Cougar, 2.5 MTX, Laser Red - May 5, 2009 - March 2, 2012 RIP
    New Ride - 1999 Cougar, 2.5 ATX, Tourmaline Green - March 16, 2012 - Present
    2000 Oct
    Minneapolis, MN
    7,473
    It was ~-25F here last week.
    gustavoperez507: We aren't too far from you so if you do decide to go with a new motor check our pricing out for 3L motors. You might end up paying close to our 3L install price to fix your issue. Otherwise, we could install a stock motor cheaper than almost any shop would charge you. If you don't know what to do you could have the car towed to us and we can tell you what would be the cheapest route to get it up and running.
    Click here to see my Cougar.
    2011 Feb
    4
    Noob stop making post and get to work.
    Fun in the Snow on Vimeo
    2000 Oct
    Minneapolis, MN
    7,473
    Nice. Is that your video or something you stumbled across online. The plates are MN plates on those cars.
    2011 Feb
    4
    No I have meet the kid with the baby blue rx-7 up at university. He live some where around lakeville. He was on 507forum in the past and now comes to minnesota sport compact.
  9. #8
    2011 Jan
    8
    Im not a noob your the noob! Ill have my coug up and running anytime sooon!!!! Get off this cougar form and get back to your MNhonda!
  10. #9
    2011 Feb
    4
    Gustavo perez do not be up set that your cougar does not run. Your just mad your cougar will never run as hard as a honda.
    Honda Day 2010 on Vimeo
  11. #10
    2000 Oct
    Minneapolis, MN
    7,473
    I've been to a few MSC meets. I'll try to get out to a few this year.
    Gustavo,
    What did you end up doing with your car? Was the engine shot?
