Go Back   NECO Forums > Chapters > Minnesota NECO
Old 12-01-2006, 10:03 PM   #1 (permalink)
Tommyboy's Avatar
Has anyone in here installed those Reverse Indigo gagues?
Fellas, i picked up a set up Indigo gagues off Afroman and i want to install these mo-fos, but i have never really done it before so i was wondering if any one on here has done them? I dont think they seem too hard, Iv seen the how-to on how to do them, but i get confused on is where to install the light cables on the gagues to? Has anyone in here installed them before? I dont recall anyone in our fourm with them...?
Key my car and i will rip ya a new Bung-Hole!
http://www.myspace.com/22237139
Tommyboy is offline
Old 12-01-2006, 11:13 PM   #2 (permalink)
LEVIATHANN's Avatar
Cool Re: Has anyone in here installed those Reverse Indigo gagues?
VERY VERY SIMPLE... Once cluster is removed, use a fork to carefully remove the needles. Install the gauges and install cluster without replacing the cluster plastic cover. Replace each needle exept for the rpm nedle and fuel needle. Remember to note how much glass you had. Turn on your car and place the rpm needle but not all the way in( this needle needs to be calibrated) once you have it in the right position then you can push it in. Do the same for the gas needle. Remember to LOOK AT THE NEEDLES BEFORE REMOVING THEM! so you can remember how far to push them in!!!
LEVIATHANN is offline
Old 12-02-2006, 04:38 AM   #3 (permalink)
Tommyboy's Avatar
Sweet thank you, now where would i hook up the light cables for my indigo lighting?
Tommyboy is offline
