Go Back   NECO Forums > Chapters > Mass/Conn NECO
Old 04-01-2008, 08:27 PM   #1 (permalink)
AndrewM6097's Avatar
Its in
the 3L is in and running. Its been a long week! seems to be running pretty good so far besides the check engine light for IMRC stuck open. I'm gonna look into it tomorrow. I have a spare one but is there anything else i should check out??
1999 MTX, 3.0, silver frost SVT UIM,LIM,CAMS,TB,INJECTORS,ECU,CLUTCH. AEM-GMK. MSDS-TRUBENDZ-MAGNAFLOW. FIDANZA. B&G-KYB-JAGED RSTB. ADR. ALPINE. 215HP, 191TQ
AIRCOUGAR PERFORMANCE
AndrewM6097 is offline
Old 04-01-2008, 09:13 PM   #2 (permalink)
cannondalemtb's Avatar
Re: Its in
If you have a spare one, I would go ahead and just swap it out. It's easy enough to do. If that doesn't work, then I would start wondering what else it could be.
99 3l SeVT, 98 SVT #135
Former owner of:
#4427,#1119,#9
http://i18.photobucket.com/albums/b121/zorrex/airperf2.gif
cannondalemtb is offline
Old 04-01-2008, 11:15 PM   #3 (permalink)
brapple's Avatar
Re: Its in
good deal. If the unit is reporting a stuck open code then it is most likely the unit or the cable. inspect the cable to see if it is broken and repalce as needed.
and enjoy the 3L!
- 95 Mystique LS Zetec 5-spd
- 2k Contour SVT - #2137
brapple is offline
Old 04-02-2008, 01:57 AM   #4 (permalink)
You Got Rondo'd!
aircougar1's Avatar
Images: 1
Re: Its in
Nice Job Andrew! very good to hear!
I posted in another section, too, but check to make sure the LIM linkage rod isn't getting stuck on the injector harness near the bottom of the TPS sensor... and make sure you don't have any broken square plastic bushings for the 2 linkages, either...
"YAHTZEE!!!!"
1999 Laser Red Cougar Mtx
aircougar1 is offline
Old 04-03-2008, 12:33 AM   #5 (permalink)
Protect the Cassel
COOGAH's Avatar
Re: Its in
Originally Posted by AndrewM6097 View Post
Its in
thats what i usually have to tell the chick i'm with......
Ad Space For Sale
COOGAH is offline
Old 04-03-2008, 02:19 AM   #6 (permalink)
You Got Rondo'd!
aircougar1's Avatar
Images: 1
Re: Its in
and then 2 pumps later, you say.........
I'm Done!
"YAHTZEE!!!!"
Old 04-03-2008, 09:09 AM   #7 (permalink)
Newcat016's Avatar
Re: Its in
I'm Done!
Ouch, and andrew, just keep ur rpms above 3500 and u'll never know the difference
Newcat016 is offline
Old 04-03-2008, 11:06 AM   #8 (permalink)
Re: Its in
Is that because you so small or are the girls you're with that loose?
ctmystique is offline
Old 04-03-2008, 03:51 PM   #9 (permalink)
Re: Its in
Argh.... looks like i'll be redoing the timing this weeknd
Old 04-03-2008, 03:58 PM   #10 (permalink)
brapple's Avatar
Re: Its in
why so? some of know what to listen/observe for if the timing is off
brapple is offline
