Go Back   NECO Forums > Chapters > Maryland NECO
Old 07-03-2008, 01:05 AM   #1 (permalink)
rear control arm
Woooow finally figured out what was chewing up my back drivers side tire. It just got real bad in last month and ate up a tire in that time. So I stuck nose alllll up under the car and found the Front Lower Control Arm twisted where it was hard to see (guessing its been getting more tweaked by bumps) with a nasty bend in it.
Now I was thinking hmm 3 bolts in the while thing this can't be hard to do. Annnnnd Theeeeeeeen...... The beaaaautiful people at ford decided that one of the bolts should hit the gas tank before it comes out (could have put the nut on that side and been way easier) Instead you have to drop (I think its called)the whole subframe back there!!!!!!! Not fun....
daemond is offline
Old 07-03-2008, 01:08 AM   #2 (permalink)
buyer beware
kustomcougar's Avatar
Re: rear control arm
your saying that fords is dropping your gas tank to put a rear control arm on???
"Open The Door, It's The Mobu With The Green Tea Beotch"- J. Geils
kustomcougar is offline
Old 07-03-2008, 01:22 AM   #3 (permalink)
shoot me now
please read.
to change out the control arm you need to drop the subframe b/c the gas tank is in the way
BUY COUGARFEST RAFFLE TICKETS
jaged is offline
Old 07-03-2008, 02:01 AM   #4 (permalink)
Karma just kicked ass
wadespencer99's Avatar
Images: 7
And you have to drop the front subframe to change the driver's side front control arm. I love Ford engineers
CFX 1st Place Mild
wadespencer99 is online now
Old 07-03-2008, 02:07 AM   #5 (permalink)
deliveryguy's Avatar
Wait...you do? I just cut the bolt and installed a new one upside down.
WTB
•99-00 Fog Lamps •Aussie Corner Reflectors (01-02) •99-00 Wheel Cap
deliveryguy is offline
Old 07-03-2008, 02:12 AM   #6 (permalink)
Images: 7
Or that way...lol
CFX 1st Place Mild
Old 07-03-2008, 09:56 AM   #7 (permalink)
If I had another bolt at the time that is probably what would have happened. Why they didn't just put the nut on that side i will never know
daemond is offline
Old 07-03-2008, 10:18 AM   #8 (permalink)
frinesi2's Avatar
Images: 6
I would just cut it and replace every bolt you take out with a grade 8 bolt and a lock nut.
I fix my car all of the time. Nothing else matters, not school, not sleep, not my bank account. But for those ten seconds or less, when everything works right, I'm free.
frinesi2 is offline
Old 07-03-2008, 08:48 PM   #9 (permalink)
Tigg's Avatar
Images: 10
Yuck. At least you figured it out...
~*~ Nicky ~*~
2000 Spruce Green v6 mtx ~ Tigg@CougarDB
2004 Twilight Blue 6MT G35 Coupe
Tweeter 3-18-77 ~ 7-9-03
Tigg is offline
Old 07-11-2008, 09:41 AM   #10 (permalink)
StealthyWeasel's Avatar
Even putting in the bolt the correct way does not require removal of subframe. Why? Because I didn't. All you have to do is jack up the powertrain with a floor jack and pry it apart a little with a prybar.
Suspended animation, state of bliss.
StealthyWeasel is offline
