Go Back   NECO Forums > Chapters > Maryland NECO
Old 07-11-2008, 10:00 AM   #11 (permalink)
Re: rear control arm
Hmmm don't see how you did that that would be alooot of prying hmmmm...
Originally Posted by StealthyWeasel View Post
Even putting in the bolt the correct way does not require removal of subframe. Why? Because I didn't. All you have to do is jack up the powertrain with a floor jack and pry it apart a little with a prybar.
daemond is offline
Old 07-11-2008, 12:02 PM   #12 (permalink)
StealthyWeasel's Avatar
100% certain it works.
StealthyWeasel is offline
Old 07-11-2008, 12:21 PM   #13 (permalink)
shoot me now
for the inside of the toe arm yes, for inside of the control arm no. the only way to access the control arm is from the top side of the subframe
BUY COUGARFEST RAFFLE TICKETS
jaged is offline
